Pressure plate problem?
Old Jun 21, 2009 | 07:31 PM
quick_ls's Avatar
Default Pressure plate problem?
Im looking for a few suggestions on with a problem i have.
the cars a 2001 integra with b18 and turbo kit. The clutch is ACT 6 puck unsprung with act extreme pressure plate. I had purchased a new disc to replace my somewhat worn out on. When we removed the tranny and pressure plate, i noticed that there was more wear on the pressure plate and flywheel then i expected. I had the flywheel machined to specs, and had the pressure plate smoothed out.
We put it all back together, started the car, went to move it and it wont go in any gear while cars running. Its like the clutch wont disengage. Theres also a creaking noise when the clutch pedal is pushed to the floor.
The master cylinder was leaking, so i replaced it. had it bled, and still same problem. The shift fork does move side to side.
So any suggestions?
my next step is going to be to try a stock pressure plate and see if thats the problem before i spend 350 on a pressure plate
$$broke_db8
May 22, 2005 07:22 PM
Sohc Driver
Jul 26, 2004 08:09 PM
zbower7
May 26, 2004 12:52 PM
MrEg
Sep 17, 2003 04:59 PM
Just Checking In
Mar 27, 2003 09:41 PM
