power window problem.......PLEASE Look!
Old Jun 26, 2009 | 12:40 PM
buttsneeze's Avatar
Default power window problem.......PLEASE Look!
I have a 2000 CR-V SE and for awhile now the driver's side front window has been slow to roll up. Well, it finally came to the point that it won't go all the way up..........correction, i can get it to go all the way up if i pull on it and rev the engine at a higher rpm. it goes down no problem, though. I took the door panel off and sprayed silicone spray in all the moving parts (including the rubber side pieces). it didn't really help. What do you guys suggest?
by the way, i know i am posted in the integra forum, but i just want to give others the chance to see my problem........
Old Jun 26, 2009 | 05:16 PM
94 ls-r's Avatar
Default Re: power window problem.......PLEASE Look!
The motor could have a short in it which would require more power to roll it up. Thats why you have to rev it up.
Old Jun 29, 2009 | 07:19 PM
buttsneeze's Avatar
do i have to get the whole motor/regulator assembly or can i just replace the motor? or is it just easier to replace the whole thing at once?
where do you guys suggest i get my replacement motor?
Old Jun 29, 2009 | 07:47 PM
KILLAB17VTEC's Avatar
Genetically Gay
i think you're short on ground wire somewhere.this what happen to my integra the window was hard to rollup all the way and easy to roll back down.i'm thinkin is bad motor but is not.i reground the wire,now its workin perfect like before.
Old Jun 30, 2009 | 03:55 PM
94 ls-r's Avatar
Try hookin another ground to the motor first like they said. The only place i buy oem parts from is honda. That way ya know its right
buttsneeze
Jun 30, 2009 07:32 PM
sooskay
Sep 9, 2006 06:59 PM
holeeray
Mar 6, 2005 01:36 PM
professorman
Nov 17, 2004 10:54 AM
