power steering pump bracket
Old Nov 29, 2008 | 07:44 PM
da itr-t's Avatar
Default power steering pump bracket
I'm currently doing an ls vtec on my 93 rs.
Itr head, stock bottom end.
Problem is, stock a1 head uses a different power steering pump bracket than the type r head...
and im not too sure whats compatable. Maybe gsr? del sol? Anybody know if the bottom bracket will have to be changed as well if i change the top one?
Thanks
Old Nov 29, 2008 | 08:15 PM
rebelteggy's Avatar
hey dude check this out it might be of help to u and ur problem
http://g2ic.com/forums/showthread.php?t=186096
Old Nov 30, 2008 | 05:35 AM
da itr-t's Avatar
Thanks, that was helpful, he said he used his stock ls bracket, which looks nothing like mine... im still confused as to which bracket they used.
My sock ls bracket bolts on level. The bolt holes look something like this O O (a1)
Yet on the head, the bolt holes are about a half inch off set like this O (itr)
O
Also, if i try to just use the left bolt hole from the ls bracket, in the left bolt hole from the itr head it still is too high for the pump to bolt onto.
Any ideas??
MyEfSi2Slow
May 3, 2011 10:28 AM
will_quach
Jun 16, 2010 01:55 PM
stelteg
May 1, 2009 09:28 PM
HondaGuy02
Apr 17, 2005 07:22 PM
DSRxCandyh2bEG
Jun 21, 2004 10:24 PM
