Possibly be the ABS???
Old Oct 2, 2007 | 05:32 PM
SickIntegraWon's Avatar
Default Possibly be the ABS???
I have this weird sound around 3400 rpms, and it does it every single time Iam in that rpm range in any gear. It was doing it before my motor swap and still does it now. Is it my ABS?
Old Oct 2, 2007 | 06:10 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Possibly be the ABS??? (SickIntegraWon)
Could you be a bit more specific? I really doubt that it is the ABS.
Old Oct 2, 2007 | 07:57 PM
Default Re: Possibly be the ABS??? (Dogginator)
Well the sound is always at the same rpm, ive done a complete motor swap, and its still there. Kinda tough to explain the sound of it
Old Oct 2, 2007 | 08:03 PM
aaronISthrowed's Avatar
Is it the heat sheild rattling? Describe the sound. Does it sound like someones holding a playing card to fan blades or what?
Old Oct 2, 2007 | 08:21 PM
Jtuned DC2's Avatar
* B A N N E D *
Desrcibe the sound. Is it whistling? rattling? Clinging?
Old Oct 3, 2007 | 12:28 PM
Default Re: (Jtuned DC2)
Its not a rattling sound, not clicking sound, non of that. Very hard to put a finger on it. It also used to do when i first started my car early in the mourning
Edit: Removed my abs relays and the noise went away. Anyone know how to fix it, because I dont really have time to go thru the trouble of deleting the whole abs system
Edit: Never mind noise came back!
Modified by SickIntegraWon at 9:13 PM 10/3/2007
Old Oct 3, 2007 | 04:20 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (SickIntegraWon)
Does the ABS light come on?
Old Oct 3, 2007 | 08:15 PM
Default Re: (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Does the ABS light come on?</TD></TR></TABLE>
Not sure i have a Jdm type r cluster..
Old Oct 4, 2007 | 04:27 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SickIntegraWon &raquo;</TD></TR><TR><TD CLASS="quote">
Not sure i have a Jdm type r cluster..</TD></TR></TABLE>
Does the ABS light illuminate when you start the car? If not, replace the bulb.
Old Oct 6, 2007 | 05:36 PM
Well it doesnt, and i can quite remember if the abs light was lit when i have the other cluster. I have removed al the abs fuses/relays from the ABS fuse box, and the noise is still there..
Old Nov 8, 2007 | 09:28 PM
sexy240tooDIE4_SR's Avatar
i thinks it your V-TAK......
Old Nov 8, 2007 | 09:32 PM
ls19integra95's Avatar
Default Re: (sexy240tooDIE4_SR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sexy240tooDIE4_SR &raquo;</TD></TR><TR><TD CLASS="quote">i thinks it your V-TAK......</TD></TR></TABLE>
if you removed all those fuses and relays then i really dont think its your abs... ever think of checking suspension, or maybe even something inside your cars vibrating and those rpms, are your motor mounts shot? also might be something inside your trans... also to remove abs system not too hard or long... need 4 lines, master cylinder and brake booster and a 40/40 prop valve did it on my ls and only took couple hours
Old Nov 10, 2007 | 04:29 PM
Default Re: (ls19integra95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls19integra95 &raquo;</TD></TR><TR><TD CLASS="quote">
if you removed all those fuses and relays then i really dont think its your abs... ever think of checking suspension, or maybe even something inside your cars vibrating and those rpms, are your motor mounts shot? also might be something inside your trans... also to remove abs system not too hard or long... need 4 lines, master cylinder and brake booster and a 40/40 prop valve did it on my ls and only took couple hours</TD></TR></TABLE>
I really want to remove it!. Where do i get the 4 lines from?. I believe the master cylinder and brake booster have to be from an rs. Does the 40/40 prop valve also come from an rs model?
Old Nov 10, 2007 | 07:35 PM
yes and i got the 4 lines from the dealer theres a post that tells you exactly what lines they are too...
Old Nov 11, 2007 | 12:08 PM
Cool bro thanx for the help
Old Nov 16, 2007 | 06:00 PM
no i still say its ur flux capacitor/ v-tak control acctuator......
Old Nov 16, 2007 | 07:11 PM
Blahblah718293's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sexy240tooDIE4_SR &raquo;</TD></TR><TR><TD CLASS="quote">no i still say its ur flux capacitor/ v-tak control acctuator...... </TD></TR></TABLE>
x2... any newb could tell that just by his description
kbxer22
Honda Civic (2001 - 2005)
Dec 24, 2006 07:29 PM
mr devious illusions
Aug 7, 2004 11:09 PM
Havokgsr
Dec 15, 2002 01:11 AM
pr0jektdc2
Sep 29, 2002 11:22 PM
es four
Apr 30, 2002 08:51 PM
