Possible power lost
Old Dec 28, 2005 | 09:20 AM
civicracer03's Avatar
Default Possible power lost
A while back i experience a lost in power. Pretty much tried everything to figure it out. Compression test, fuel pressure, ignition, and couple of other things. One thing that keept me curious is that a mechanic had a laser temperature reader. He pointed that headers 2-4 are the same temp but header tube 1 is 50 degrees lower than the rest. Those any body know what could be causing this. Could it be a faulty injector? would this be the cause of my slower accelaration.
Old Dec 28, 2005 | 05:54 PM
Default Re: Possible power lost (civicracer03)
Come on has anybody ever had a problem with their gsr with i/h/e were it started to performed slower accelation. example struggle to hit 8000 rpm in fourth gear straight away or worse on up hill highway.
Old Dec 28, 2005 | 06:33 PM
Dogginator's Avatar
Daisy... Daisy...
Clogged injector(s)?
Old Dec 30, 2005 | 08:11 AM
Default Re: Possible power lost (Dogginator)
its gonna be one hell of a clogged injector since took out and tried cleaning them. I was running rich at the time. check engine light came on for the o2 sensor wire that got loose. Would be surprised if it fried something.
Old Dec 30, 2005 | 09:23 AM
Dogginator's Avatar
Daisy... Daisy...
What year is your car? Is it missing or running roughly? Does the spark plug in cylinder 1 look different than the others?
Old Dec 30, 2005 | 10:49 AM
TurdBlown Teg's Avatar
well did you get a new o2 sensor those help out alot i would say its that. some one correct me if i am wrong but i dont think i am.
Old Jan 3, 2006 | 08:09 PM
Default Re: (kevin716)
no check engine now but i did change the first o2 sensor
MagicalMike
Nov 26, 2011 03:23 PM
MurtazaDSM
Oct 18, 2011 12:58 PM
bradennicely
Nov 19, 2009 02:50 PM
InvaderTrax
May 4, 2008 01:57 PM
BEEYOND
Sep 20, 2004 08:42 PM
