Please help we with...
Old Jun 13, 2001 | 10:24 AM
integsra's Avatar
Default Please help we with...
...a couple of things wrong with my 94 GSR.
First, for about the last week or so, I have noticed a huge amount of gear shift travel during acceleration. Does anyone know what could be causing this? Here's the scenario: I put it into gear and it is fine, but when I take off, the shifter will go forward about another inch and then when I let off the gas it will come back to its original spot. If I am doing any sort of spirited driving, it is even worse. Could it be the engine, transmission, or even the shifter bushings? I haven't checked any of them.
Also, mostly when I just start driving the car, and am making left turns, I hear a loud clicking coming from the passenger side wheel area. Is this most likely the CV joint or are ther other possibilities. I jacked up the passenger side of the car and spun the wheel and there was a tiny clicking noise, but the other wheel did the same thing and I don't hear it when turning to the right. There were also no visible rips in the boots on the axles.
Thanks in advance for any help.
Integsra
[Modified by integsra, 11:26 AM 6/13/2001]
[Modified by integsra, 10:01 AM 6/15/2001]
Old Jun 13, 2001 | 10:58 AM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: Please help we with... (integsra)
For the first problem, jack up the car and check to see if the bolts on the shift linkage is tight. It may have come loose, causing a lot more travel than usual. Check at both ends at where the linkage connects to the tranny and where it bolts to the shifter end. Also double check the bolts on your tranny and the condition of the rubber mounts.
For the second problem, check your brake lines to see if they are contacing anything. Also check the shields around the calipers to see if they are touching anything. Basically go over everything that could be touching a turning object. If still nothing, bring it to someone that can check to see if your axles are messed up internally. I'm not sure how to check that so i can't help much there.
Good luck!
Old Jun 13, 2001 | 01:55 PM
VTEC4GS's Avatar
maybe your motor or tranny mounts went south ?
Greg
Old Jun 15, 2001 | 09:03 AM
integsra's Avatar
Default Re: Please help we with... (Gee3)
Thank you guys for your input. I will try to check these things out tomorrow and will get back to you with the results.
Sorcin
Oct 18, 2010 08:21 PM
T"u"Rtle
May 29, 2006 09:39 PM
ZexyAccord
Dec 20, 2004 09:23 AM
Andrew 825SM
Aug 23, 2004 09:51 PM
radio1global
Jan 25, 2004 03:44 PM
