PLEASE HELP ME!! Car Problem!!
Old Jan 24, 2004 | 07:46 PM
radio1global's Avatar
Default PLEASE HELP ME!! Car Problem!!
Alrite guys im really worried..My babys F#$# up. Alrite heres the run down straight to the point.
1.At over 20mph my car shakes (shifter, steering wheel)
2.Lot of clicking noise from the passenger wheel (cv boot?)
3.The noise is with the speed, meaning if I go fast it clicks, shakes more and if I slow down the same.
4. Only things that shake alot are the wheel, and the shifter.
Car: 01 Gsr , been driving it ALOT lately.
The Cv boot was leaking about 3months ago and I never got around to fixing it.
Just need your help guys on an idea of whats wrong! thanks please help me without any flaming!
Old Jan 24, 2004 | 07:47 PM
integraL's Avatar
Default Re: PLEASE HELP ME!! Car Problem!! (radio1global)
wanna try balancing you tires, maybe?
Old Jan 24, 2004 | 08:47 PM
florduhdude's Avatar
Default Re: PLEASE HELP ME!! Car Problem!! (integraL)
Change your axle and see what happens.
Old Jan 24, 2004 | 08:49 PM
Spoon 722's Avatar
Your car might be shaking do to warped rotors, but i'm not sure about the clicking noise.
Old Jan 24, 2004 | 09:27 PM
..::91TEG-G2::..'s Avatar
its ur cv... ima tell u somethin, fix it QUICK.. you should know how thoes work, and if that oil/lube comes off, and thoes joints rub on the cv... it could snap while ur driving.. and u dont wanna know the outcome of that.. make sure to check that first, and even if its not the problem, get it fixed
Old Jan 24, 2004 | 10:59 PM
Yeah thanks for the responses, Im almost 90% sure its about to snap because it shakes badly and clicks badly. I remember about 3months ago I was told by Acura that it was leaking but I didnt have the option of keeping my car there due to work. But thanks if anyone else has any input please do help.
Old Jan 24, 2004 | 11:44 PM
turboant's Avatar
frist the clicking it the cv joint but the shaking mean that you need alignment then you shoud be cool
Old Jan 25, 2004 | 08:11 AM
SIanara's Avatar
try getting under the car and moving the axle with your hand... does it get really bad when you turn under power? how is your axle bad with an 2001 if i might ask? lot of miles?
Old Jan 25, 2004 | 03:44 PM
Default Re: (vteGraGSR)
he could of tore the boot over the cv joint and ish could of gotten in there.. i mean it could be you can check it out, put greese on it again and buy a new boot and BOOM... or set.. or it could be worse, depends
dopesk8er87
27
Apr 9, 2013 07:51 PM
Sorcin
Oct 18, 2010 08:21 PM
TunerShark
25
Nov 4, 2006 03:30 PM
WRTEG
Aug 18, 2004 02:15 PM
REDBARON
14
May 24, 2001 07:25 PM
