please help guys
Im about to buy an 98 GSR, theres a problem i am concerned about, the engine will like jump while its idling. but the rpms do not drop, and it does not do it while im driving, is this a motor mount problem?
From: You can be my wingman anytime...., Las Vegas, US
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luvmy96honda »</TD></TR><TR><TD CLASS="quote">Im about to buy an 98 GSR, theres a problem i am concerned about, the engine will like jump while its idling. but the rpms do not drop, and it does not do it while im driving, is this a motor mount problem?</TD></TR></TABLE>
I'm confused... Define "jump."
When does it do it.... all the time? (all the time it's idling?)
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Get it checked out by a good mechanic. If the seller won't let you than it might be shady and something could be wrong with the car.
Be smart and get it checked out first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra707 »</TD></TR><TR><TD CLASS="quote">
When does it do it.... all the time? (all the time it's idling?)</TD></TR></TABLE>
yes define your definition for "jump"
at ild the motor shouldn't be jumping or shaking at all...it could have small vibration...it only have a strong shake when it ignition-start up then it must settle after that...and calm when it gets warmer
problem can be (possibilities but not warranty that it is)
1. motor mount are losen or some speical motor mount might have installed in your engine's bay
2. motor is running way too lean
3. is your weather cold? or etc
4. air intake is choking the motor at start up check for clogged
5. starter is dying out
6. miss timing
hey man that much is all i can think of...gl dude...hope it will help ya out
3.
yes define your definition for "jump"at ild the motor shouldn't be jumping or shaking at all...it could have small vibration...it only have a strong shake when it ignition-start up then it must settle after that...and calm when it gets warmer
6. miss timing
3.
Rocks
11
Jul 23, 2004 11:19 AM
Petah
May 15, 2004 04:27 PM
