please help! geting code 43 on a 99 lsvtec
Old Aug 28, 2010 | 05:14 PM
superhatchbackbros's Avatar
Default please help! geting code 43 on a 99 lsvtec
hey can someone please help me! im geting a code 43 for the first time since i built the motor! it has about 6500 miles on it. i feel no loss of power ETC and drives and runs smooth and idel perfect still! i was wondering what could cause this? anyone??? also only new thing i did was put a air fuel gauge in it! and it just reads lean all red and half the yellow is light up! doesnt bounce around or anything.. is that odd? im converted down to obd1 with a ls vtec chip.. i did tamper with the o2 sensor with the white wire then went to green and back to white! and read beter on the white wire! could i have messed up the o2? and have this problem now? please someone help me thanks in advanced!
Old Aug 28, 2010 | 08:09 PM
el crapitan's Avatar
Default Re: please help! geting code 43 on a 99 lsvtec
i'm not sure i understand what is happening with the A/F gauge. it's just reading lean? if so, you probably do have a problem with O2, and that is where the code is being set from.
your engine will still run fine off set parameters based on rpm and load.
either way, since you've tampered with the O2, i'd suspect it is the cause of the code
Old Aug 29, 2010 | 10:35 AM
ya i tampered with it pretty good! i thnk its the problem! im going to get a new one and just splice into it one time since i know its the white one now! bc like i said befor it never did this code until i spliced a into the o2! plus maybe my o2 is bad or went bad and thats why my gauge is reading all red and yelow light up on the a/f gauge! weird
fminusmic
Apr 12, 2018 02:07 PM
RSant
Feb 8, 2007 05:49 PM
JD95hatch
May 18, 2006 02:51 PM
djtony5
Feb 3, 2006 12:34 AM
_SHIFT
Mar 17, 2005 07:53 AM
