Please Help
Old May 13, 2005 | 01:03 PM
jokr78's Avatar
Default Please Help
need torque specs on 96 b18c for engine rebuilding....please help
Old May 13, 2005 | 01:14 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Please Help (jokr78)
Which torque specs? For which part? I have the helms here......
There are hundreds of torque specs for an engine build.
Old May 13, 2005 | 01:31 PM
shamoo's Avatar
Default Re: Please Help (shamoo)
This is in response to the original posters request: jokr78 (5:19 PM 5/13/2005): KEWL.. i need the torque spec for the head to block, rods, and cams....?
For STOCK parts (i.e.: not using ARP headstuds, etc):
CAMS:
After putting on the cam cams, camshaft holder, you need to torque the holder down according to these settings:
20ft-lbs (apply engine oil to threads)
Outer 4 bolts of holder (6mm bolts) should be torqued @ 7.2ft-lbs
Camgears should be torqued to the cams @ 41ft-lbs
HEAD:
Cylinder head should be torqued down in two stages. The first stage, they should all be torqued to 22ft-lbs. Then to 63ft-lbs. Engine oil should be applied to bolt threads.
BLOCK:
Bearing caps should be torqued @ 56ft-lbs
Rod bolts should be torqued @ 33ft-lbs for the B18C1 and 23ft-lbs for the B18B1
IMPORTANT: These should all be torqued down in sequence, of course. In a criss-cross pattern
Lemme know if you need more specs. There are a lot more here, obviously.
micspit vtec
K Series
May 5, 2011 02:44 PM
StraightCivic
Apr 27, 2006 11:09 PM
I got a honda
Oct 19, 2005 08:06 PM
tuan...
Nov 20, 2004 01:37 PM
BloodRedTeg
Mar 9, 2004 01:32 PM
