piston ring size???
Old Dec 24, 2001 | 09:33 PM
NOSed_b18b's Avatar
Default piston ring size???
OK. I have basically leaned towards the usdm type r .25 overbore piston set for my setup. My question is, what size piston rings do I use??? I looked on the total seal website, and they only offer std size, .20, .30, etc. overbore sizes. Would I just use the bigger sized .30 for my pistons, or am I just forced to use the stock replacements??? Do those sizes by total seal mean that I can use up to that piston overbore size??
[Modified by NOSed_b18b, 6:37 AM 12/25/2001]
Old Dec 25, 2001 | 05:35 AM
non-VTEC's Avatar
Default Re: piston ring size??? (NOSed_b18b)
ONLY use OEM honda rings with those pistions. Total Seal rings are Total CRAP
you can get oversized rings with those ITR pistions from the dealer.
Old Dec 25, 2001 | 11:43 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: piston ring size??? (non-VTEC)
are you sure they are 25 over? Most of them are 10 or 20 overs.
Call JE, they might have high tension rings that will fit.
Total **** rings are exactly that
OE rings can go bad at high RPM's, but they're better than TS
I use JE high tension rings.
turbo boost
Oct 27, 2014 11:09 PM
hondachris1994
23
Feb 9, 2009 07:55 PM
95blackEG
May 23, 2007 02:50 PM
DC2TT
Jan 9, 2006 07:47 PM
da6_b17a
Oct 20, 2001 02:02 PM
