Phillips HID
Old Mar 8, 2003 | 07:08 PM
Pinkertinkle's Avatar
Default Phillips HID
I just installed a phillips 4300K HID kit on my 00 gs, but the passenger side lamp keeps blowing the 10 fuse, should i replace with a 15?
Old Mar 8, 2003 | 07:14 PM
daLixz25's Avatar
Default Re: Phillips HID (2kGS)
yes. or maybe a 20.
thaiphob's Avatar
Nikon!!!
a common problem with the HID's. 15 should be okay. to be safe go wit a 20
Old Mar 8, 2003 | 07:21 PM
Default Re: Phillips HID (thaiphob)
Will do, thanks for the info!
Now I can go try to aim them properly, any tips?
Old Mar 8, 2003 | 07:28 PM
BTW, which direction screw driver turn makes the lights angle more up? Clockwise or counter?
Thanks
Old Mar 8, 2003 | 08:14 PM
With the stock setting the main spread is hitting the ground 6 feet in front of the car, I've been turning the thing clockwise forever and the spread doesn't seem to have moved. The bubble is all the way too the front now. Is there some point where I will no longer be able to turn the adjustment screw/wheel thing?
Old Mar 8, 2003 | 09:29 PM
PureTeg420's Avatar
there are two adjustment screws per headlight. Odds are you are turning the screw that affects the horizontal spread of the beams, instead of the the vertical which actually determines how high your lights aim
Old Mar 8, 2003 | 10:33 PM
gsxr's Avatar
Default Re: Phillips HID (PureTeg420)
yep
V.T.E.C.
Aug 12, 2008 08:20 AM
J.nguyen
Honda S2000
Aug 13, 2007 11:44 PM
Understeer
Dec 5, 2002 09:10 AM
speedymon
Nov 19, 2002 11:28 AM
CheezeFrog
Aug 8, 2001 03:27 PM
