Performance Mods I will never do...
Old Oct 29, 2001 | 11:32 AM
VTechie's Avatar
Default Performance Mods I will never do...
I've done some mods that I have subsequently removed, or else regretted later, such as:
Slotted Brake Rotors (warp-o-rama)
Filter-On-A-Stick (worthless!)
Others I consider way too expensive and/or dangerous to do (even if the performance gains could be awesome):
Turbo
Head Milling
NOS
Old Oct 29, 2001 | 11:55 AM
owen_the_soyboy's Avatar
Default Re: Performance Mods I will never do... (VTechie)
yah on the slotted rotors, I have since changed to BIGGER brakes, not pretty brakes.
~It was a waste of time for the pretty brakes... should have gone big in the first place. DOH!
you think head milling too dangerous/pricey? My local shop qouted me $35 to mill the head .020", as long as I am the one that disassembles it. Now, that is not an expensive mod, just time consuming!
Old Oct 29, 2001 | 12:00 PM
HX_Guy's Avatar
Default Re: Performance Mods I will never do... (owen_the_soyboy)
I think I need to get rid of my cross drilled rotors as well...and upgrade to bigger.
Damn these brakes are starting to suck..they get way mushy after breaking from 90 MPH just once
Stupid stock HX brakes.
Old Oct 29, 2001 | 12:20 PM
VTechie's Avatar
Maybe not too pricey- but if the milling isn't done with great care, the results can be disaster: taking too much off, plunging too far with the end mill, not being completely level, that sort of thing could result in buying a new head.
Old Oct 29, 2001 | 01:09 PM
Apollo Creed's Avatar
New User
Filter on a stick sucks. Cold air is where the power's at!
Old Oct 29, 2001 | 02:23 PM
mamaboy's Avatar
I don't know...filters are too overhyped definately.....
especially cold air filters....BAD THINGS CAN HAPPEN.....
i'd rather invest in the comptech intake kit...
that includes the cold air box.....no chance of water injestion since it's pullin air from behind the turn signal....and the pipe and filter kit from comptech...and the box is directing air to the filter instead of the filter being the sole source of the air injestion
or better yet if you have money....the mugen intake kit......
Honda made the air delivery to your car efficient...why not use their idea and make it better....instead of makin drastic shortcuts
MUGEN...KINGMOTORSPORTS http://www.kingmotorsports.com/produ...gra/engine.asp
COMPTECH USA http://solar.innercite.com/comptech/intake8.html
Old Oct 29, 2001 | 02:25 PM
samagon's Avatar
I voted nos, but turbo is a close second with the slotted rotors a very close 3rd.
Old Oct 29, 2001 | 02:43 PM
Rory Breaker's Avatar
Default Re: Performance Mods I will never do... (samagon)
I dont have a problem with one thing on that list...
If you are educated and know what youre doing, every single one of those modifications has a very good purpose.
Old Oct 29, 2001 | 02:47 PM
HX_Guy's Avatar
Default Re: Performance Mods I will never do... (mamaboy)
Why you ask? Let me explain.
There are advantages to a cold air intake setup that do not come from the cooler air...which a conventional setup can not provide.
the length of the intake has a huge impact on air delivery into the engine due to the resonance caused (by the length).
Take a look at these:
Trsut me..the surge in power between 4200 and 5200 RPMs is not due to cooler air..especially since the results are fro ma dyno..where a regular intake gets the same air as a cold air setup.
Old Oct 29, 2001 | 06:05 PM
Type Goch's Avatar
New User
Default Re: Performance Mods I will never do... (HX_Guy)
whats your take on intakes while the car is moving? when the car is moving, isnt air constantly moving in and out of the engine bay?
Old Oct 29, 2001 | 06:47 PM
Anthony K's Avatar
New User
Default Re: Performance Mods I will never do... (Type Goch)
Don't count the turbo out so soon.
Old Oct 29, 2001 | 07:49 PM
ezark's Avatar
why did people put ' toda B specs' suck? any reason to this?
Old Oct 29, 2001 | 08:00 PM
Zulu888's Avatar
Default Re: Performance Mods I will never do... (krazE)
yah, i thought Toda Bs were good??
Old Oct 29, 2001 | 08:23 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: Performance Mods I will never do... (Zulu888)
Neuspeed lower tie bar! Waste of time and money.
Civic_07
May 2, 2008 11:59 AM
utn
Honda Civic (2001 - 2005)
Aug 9, 2007 08:30 PM
Singlecam4dr
Feb 20, 2007 04:41 PM
brad98_teg
Jan 21, 2005 11:15 PM
kkim
17
Jan 26, 2002 03:03 PM
