p30's in a ls question
Old Jun 7, 2007 | 07:30 AM
90datech's Avatar
Default p30's in a ls question
i wanted to know can you run p30's or pr3's in a stock b18a/b18b on the stock ecu. i just wanted to know cause i have to change the piston rings and i figured i just put them in now instead of going back and putting them in later. i know you should run cams with pr3's or p30's or it really pointless but i just wanted to know. i can put the cams in a little later and then get it tuned. what do yo think?
Old Jun 7, 2007 | 07:18 PM
doood's Avatar
been there done that
Default Re: p30's in a ls question (90datech)
p30's and pr3's will bump your compression to 10.9:1 and 10.7:1, respectively, from 9:1. it would be best to get a tune after putting them in to prevent detonation. i normally wouldnt say this, but even a vafc would be better than nothing.
Old Jun 7, 2007 | 07:22 PM
unknown0001's Avatar
Default Re: p30's in a ls question (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">p30's and pr3's will bump your compression to 10.9:1 and 10.7:1, respectively, from 9:1. it would be best to get a tune after putting them in to prevent detonation. i normally wouldnt say this, but even a vafc would be better than nothing. </TD></TR></TABLE>
exactly... with the CR increase it would be best to throw on a few more mods if possible or some cams to make use of the compression ratio the most and getting it tuned properly.
Your factory integra ECU is set for the 9:1 CR ratio, so bumping it up a bit would throw off the ecu data as it's set for a lower CR then you'd be running
Old Jun 8, 2007 | 08:09 AM
90datech's Avatar
Default Re: p30's in a ls question (Mr.R)
is there a base map i can run or will the safc do until i get the new head and management
bdavissi
Jan 7, 2007 08:41 PM
RenzoDaPlayboi
Nov 13, 2005 03:31 PM
elrandeeto
Jul 25, 2005 12:14 PM
ochsy03
Apr 4, 2005 05:04 PM
BlueTeg01
Oct 22, 2004 11:15 AM
