p28 question
Old Apr 8, 2003 | 07:16 PM
dtyst's Avatar
Default p28 question
I have a 95 intgera RS that I put a 98 gsr engine into , my question is if i have a chipped p28 ; when i plug it into the car do i have to run wiring for the vtec , knock or evap etc ? thanks
Old Apr 8, 2003 | 08:53 PM
kombo83's Avatar
Default Re: p28 question (dtyst)
if you are using your stock wiring harness youll have to add 3wires for VTEC and one for knock sensor.and youll need to use OBD1 ecu ,injectors,and distributor.just use your stock ones just on the distributor youll have to chop one of the legs off to make room for vtec purge assembly.oh yeah if you are using the stock intake manifold from the gsr you CANT use the p28.it doesnt have the sensors for the secondary butterflies so youll have to find a p72.or you can just get a skunk2 im then the p28 will work just fine.
Old Apr 8, 2003 | 10:11 PM
1.8DC2's Avatar
Default Re: p28 question (kombo83)
or you can go nuts and just remove the butterflies...not recomended....very ghetto...but i have seen it done
Old Apr 9, 2003 | 07:04 PM
dtyst's Avatar
Default Re: p28 question (1.8DC2)
WELL im ghetto cause i removed the butterflies , i hope it was worth it
jedsus
Jun 23, 2006 11:45 AM
.BigSexy
May 14, 2006 12:41 PM
Mushvroom
May 3, 2005 10:31 AM
GorData
Sep 15, 2004 08:38 AM
JDM DC2
Mar 12, 2002 07:32 PM
