overheating need help!!!!
Old Jun 30, 2002 | 06:13 PM
ImportRacing's Avatar
Default overheating need help!!!!
I have a ls/vtec with new internals and ported head, the problem is after i installed it my engine is running hot. All the switches and electrical works. I also made a switch to keep the fan running all time. When the thermostat was in the car the gauge was close to the H and i blow my radiator. After i took out the thermostat the engine is still hot, but only goes to half instead of the H. There is also alot of pressure build up in my cooling system. It only takes it five mins before the top and bottom hose is extremly hot to the touch. Right now im running it with out the thermostat, please help or any suggestions is welcome. I did a search already but it still is vague and need help to my integra.
engine is ls/vtec in a 95 rs teg
Old Jul 1, 2002 | 12:06 PM
Default Re: overheating need help!!!! (ImportRacing)
ttt
Old Jul 1, 2002 | 12:31 PM
junglistgsr's Avatar
get your coolant flushed (not just drained) check your radiator checked out and when you put new fluid in drop a bottle of Redline Water Wetter in with it.....theres not much we can do over the internet without looking at it in person
Old Jul 1, 2002 | 03:31 PM
Padronis's Avatar
Default Re: overheating need help!!!! (junglistgsr)
Did you try changing the thermostat, not just taking it out? You are sure there are no air pockets and that you are completely full on coolant?
Old Jul 1, 2002 | 07:18 PM
Default Re: overheating need help!!!! (G2LSS)
i haven't had the coolant flushed repalced but my radiator and thermostat from the old engine was working fine. Just that i don't know where the high pressure build up is coming from. I took my head off and the block gaurd had the holes dilled in the wrong places. Can this cause my high pressure and hot coolant.
Old Jul 1, 2002 | 07:20 PM
plus when it gets hot all the water goes to the overflow bottle but it doesn't return back to the radiator.
Old Jul 10, 2002 | 12:16 AM
Tuan's Avatar
i have the same issues
Old Jul 10, 2002 | 01:46 AM
aCuRaLsTuRbO's Avatar
Default Re: overheating need help!!!! (B20Zturbo)
cool
Old Jul 10, 2002 | 01:57 AM
Mr. Softee's Avatar
Default Re: overheating need help!!!! (aCuRaLsTuRbO)
headgasket?
Acurasforlife
Aug 31, 2011 03:03 PM
spender1326
Oct 1, 2010 12:31 PM
vlude99
Jul 30, 2009 05:58 PM
Exxel82
10
Apr 19, 2007 09:21 AM
JODYG35950
Nov 2, 2005 08:26 AM
