Overheating issue
Old May 8, 2009 | 07:17 AM
B18c1vicrx's Avatar
Default Overheating issue
i got a b18c1, the lower radiator hose is cold while the car overheats and the upper radiator hose is hot, but not too hot to touch, i figured it was the thermostat but i replaced that and it still overheats, any ideas? thanks
Old May 8, 2009 | 07:44 AM
ahcapone's Avatar
Default Re: Overheating issue
Flush your radiator to make sure that yu are getting good coolant flow through it.
Old May 8, 2009 | 09:17 AM
follie gatts's Avatar
some coolants will gel if you mix different types. you didn't put any orange gm coolant in your car did you? i agree your radiator might be full of poo and not working properly.
Old May 8, 2009 | 11:00 AM
seanbev24's Avatar
Also, you could simply have air bubbles in your system. A small amount of air trapped in there can stop coolant flow completely.
Before you changed the thermostat, was the cooling system opened up for any reason, like did you disconnect a hose or something?
Old May 9, 2009 | 01:19 AM
MrViet's Avatar
air bubbles would cause a fluctuation of the temperature gauge. Meaning it'll jump up and down as air and coolant passes through the hoses and cooling the engine. Air is hotter than the water causing temp to jump and ****. unless you got all air it won't be steady.
since u already changed your thermostat....you should i guess check that radiator.
Old May 9, 2009 | 02:19 AM
vtec maniac's Avatar
radiator is blocked or clogged
Old May 9, 2009 | 09:06 AM
B18c1vicrx's Avatar
thanks for the input, i have not mixed any coolant or opened the system, i'll flush the radiator and see if that solves the problem
Old May 9, 2009 | 10:50 AM
safe dude
Old May 9, 2009 | 04:22 PM
Mt3c's Avatar
You haven't opened the system? What thermostat did you change, the one on top of the radiator?
It sounds like the mechanical thermostat, the one in the block at the lower radiator hose has failed in the close position.
Old May 9, 2009 | 05:13 PM
Honda Tool's Avatar
2010 Honda-Tech Poker champion
Think he meant before he replaced the thermostat.
Old May 9, 2009 | 06:40 PM
seanbev24's Avatar
Air bubbles will not necessarily cause a fluctuation where the temp will jump up and down. Air can get trapped, stopping coolant flow completely, so the car will straight overheat.
Since the OP apparently has not opened the system (before his problem and changing the thermostat), then yes, it could very well be the radiator.
Old May 13, 2009 | 10:45 AM
B18c1vicrx's Avatar
coolant flush did the trick, thanks for the help!
Old May 13, 2009 | 12:56 PM
seanbev24's Avatar
Congrats and at least you came back and told us what fixed it. It's helpful for future people when (if) they do a search.
Old May 13, 2009 | 01:01 PM
WDG_729_ITR's Avatar
haha i'm glad you were sure to include the "if" part...most people don't search at all.
corince06
Jun 11, 2008 12:48 PM
accord_2dr
Oct 20, 2007 03:17 PM
-Championship-
Nov 26, 2006 07:14 PM
SleepyHF
Apr 7, 2004 06:59 PM
drumsy
Sep 12, 2002 07:14 AM
