Over Heating Please Help!
Old Apr 17, 2003 | 01:43 PM
Smoochy's Avatar
Default Over Heating Please Help!
Just got my car out of storage and i just took it for a test drive and the temp gauge went all the way to the H. I had the radiator out for a different project, and i am sure i put it in correctly. oh yeah the fans will not run either, which tells me it;s an electircal problem. i don't know what to do. help a brother out please. thanks
Old Apr 17, 2003 | 04:28 PM
seanb18c1's Avatar
Did you remember to refill the radiator?
Check that coolant level in the radiator.
Make sure all hoses are secure.
Follow the wiring from the fan cack to the ECU.
Old Apr 17, 2003 | 04:49 PM
NeoGSR's Avatar
Default Re: (seanb18c1)
stuck thermostat?
after being stored a while....don't understand why the fans don't run....fan switch perhaps?
just my .02
Old Apr 17, 2003 | 05:45 PM
Smoochy's Avatar
I did all the proper thing as far as installation goes.
Old Apr 17, 2003 | 06:13 PM
fiebru1119's Avatar
Default Re: (Smoochy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smoochy &raquo;</TD></TR><TR><TD CLASS="quote">I did all the proper thing as far as installation goes.</TD></TR></TABLE>
bleed the system?
any leaks (or can you smell coolant anywhere- sweet/pungent smell incase you didnt know)?
cant think of anything else.. thermostat?
Old Apr 18, 2003 | 01:28 PM
geminis2k's Avatar
Default Re: (fiebru1119)
make sure you have radiator fluid, if not check your water pump
Old Apr 18, 2003 | 04:04 PM
Smoochy's Avatar
Default Re: (geminiGSR)
i sealed a small leak but the fans still wount turn on. could this be a fuse out?
also only the drivers window rolls down, could that be on the same fuse? thanks
Old Apr 18, 2003 | 05:32 PM
.RJ's Avatar
.RJ
you have air in your cooling system
Old Apr 18, 2003 | 06:07 PM
Smoochy's Avatar
Default Re: (.RJ)
is that why the fans won't work?
Old Apr 18, 2003 | 06:43 PM
fiebru1119's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smoochy &raquo;</TD></TR><TR><TD CLASS="quote">is that why the fans won't work?</TD></TR></TABLE>
how long do you have the car on? they dont turn on right away.. mine turn on after its at operating temp for like 10 minutes. did you bleed the system? you might have air in your cooling system
Old Apr 18, 2003 | 06:50 PM
Smoochy's Avatar
I've driven it for about 35 min and they still didn't turn on.
Old Apr 19, 2003 | 02:20 PM
Smoochy's Avatar
bump
Old Apr 19, 2003 | 02:23 PM
.RJ's Avatar
.RJ
did you even try to bleed the air out of the system before waiting for a response?
Old Apr 19, 2003 | 02:24 PM
Smoochy's Avatar
Default Re: (.RJ)
yes i tried
Old Apr 19, 2003 | 02:26 PM
.RJ's Avatar
.RJ
how was the air bled out and what happened then?
the less information you provide the harder it is to diagnose the problem.
Old Apr 19, 2003 | 09:20 PM
Smoochy's Avatar
Default Re: (.RJ)
Thank every one but i got the problem solved!
Old Apr 19, 2003 | 09:41 PM
theman-dlh's Avatar
How did you get it solved if you don't mind me asking...
just in case it ever happens to me
Old Apr 20, 2003 | 03:34 PM
tmkpres's Avatar
Default Re: (theman-dlh)
When my fans didnt work I disconnected the fan switch and put a paper clip in the plug to make it run constint that did the trick till I got to look at it in the morning. You should try it to see if they still work
Old Apr 20, 2003 | 07:26 PM
Smoochy's Avatar
Default Re: (tmkpres)
well i guess i really didn't do a thing. one second i was over heating the next it was fine. hondas are fucked up like that. it's like they have rebuilders in them or something. well whatever it was i sure am glad that ***** over with thanks to everyone.
Old Apr 20, 2003 | 08:37 PM
Regular Series's Avatar
The fans don't usually turn on when you're driving. Only when you're in stop-and-go traffic (with more stop than go ).
Keep an eye on your temperature gauge. Problems that mysteriously disappear may mysteriously reappear. Or perhaps your thermostat freed itself up after being bathed in hot antifreeze a few times.
pyrojeff
Oct 21, 2019 09:50 AM
924doorEG
Aug 16, 2007 12:44 PM
xhatchracerx
Nov 7, 2006 08:47 AM
igo4bmx
May 19, 2005 11:58 AM
quikrpm'z
Jun 2, 2003 10:58 AM
