OT....fuel filter
Old Mar 17, 2003 | 11:31 AM
[HrZn]4life's Avatar
Default OT....fuel filter
How's it going guys. I know fuel filter issues have been covered beyond belief but I have one question. Yes I did search and read through everything but I couldn't find out what size wrenches I will need. Am I good to go with a set of regular wrenches and a flare nut wrench? What sizes too? Thanks a bunch.
Old Mar 17, 2003 | 12:00 PM
Eva01's Avatar
Default Re: OT....fuel filter ([HrZn]4life)
I believe you need a 10mm for the fuel pressure release bolt, 14mm for the fuel filter bolt and and a 17mm for the banjo bolt. Let me check on that when I get home...
When removing the nut that secures that fuel line, flare wrenches would be good if you have them but the last two times I got the nut loose using some elbow grease w/ just a regular box wrench.
[Modified by Eva01, 9:00 PM 3/17/2003]
Old Mar 17, 2003 | 12:53 PM
Default Re: OT....fuel filter (Eva01)
Old Mar 17, 2003 | 02:53 PM
Eva01's Avatar
Correction: The Fuel pressure release bolt is 12mm but all the other bolt measurements are correct. HTH
Old Mar 17, 2003 | 03:37 PM
Thanks....
k3ntegra
Aug 28, 2014 05:50 PM
calvin924597
May 28, 2010 09:55 PM
honcrx91si
Jul 4, 2007 01:47 PM
onePOINTsix
Sep 4, 2003 08:24 AM
cvc323
Jun 29, 2003 11:09 PM
