OMNI Quicklutch problem
Old Jun 23, 2006 | 01:40 PM
JThrasher79's Avatar
Default OMNI Quicklutch problem
alright i tried to put this in the All Motor forum but no replys OK, well more than half of the time when i go to my car my clutch pedal is half way closer to the ground than it is supposed to be. what could be causing this? it is bled well and the fluid is clean.
i have gotten it replaced once before because it went out, but that one did this also just not as often. im curious if this is what made the cylinder go. it shouldent matter but i have a stainless clutch line also. im stumped , any help is much appriciated..
Old Jun 23, 2006 | 01:55 PM
__oversea's Avatar
Default Re: OMNI Quicklutch problem (JThrasher79)
mmm?? omni mastercylinder's pedal is suppose to be close to the wall. very little lower than your brake pedal.
Old Jun 23, 2006 | 01:57 PM
Default Re: OMNI Quicklutch problem (Last For One)
no no. i have to put my foot under it to bring it up to the position its supposed to be in(which is still like half of stock) i cannot put it into any gear till i put it where its supposed to be..
Old Jun 23, 2006 | 01:59 PM
gsr dood's Avatar
very possible its a faulty unit. did u change the seal when u changed the omni clutch master cylinder?
Old Jun 23, 2006 | 02:00 PM
Default Re: OMNI Quicklutch problem (gsr dood)
the seal between the firewall and the unit?
Old Jun 23, 2006 | 02:50 PM
gsr dood's Avatar
yes
Old Jun 23, 2006 | 03:00 PM
__oversea's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JThrasher79 &raquo;</TD></TR><TR><TD CLASS="quote">the seal between the firewall and the unit?</TD></TR></TABLE>
i dont think that is the problem.
if you got the unit few months ago, iam sure you got the fixed version (depens on where you got it).
chcked slave cylinder for the leack?? maybe pressure plate?
Old Jun 23, 2006 | 03:03 PM
DA6righthand's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Last For One &raquo;</TD></TR><TR><TD CLASS="quote">
chcked slave cylinder for the leack?? maybe pressure plate?</TD></TR></TABLE>
type much? you post so much id figure you woulda learned to type by now...
Old Jun 23, 2006 | 03:05 PM
__oversea's Avatar
Default Re: OMNI Quicklutch problem (DA6righthand)
haha, i wasnt looking. but you get the idea...lol
Old Jun 23, 2006 | 03:07 PM
do you post in every forum?
Old Jun 23, 2006 | 03:49 PM
Racermech's Avatar
You might want to ask in the ITR forum, I know a coupl of guys in there tested the omin protos, and I am pretty sure a few of them use them in there race ITR's
Old Jun 24, 2006 | 01:11 PM
Default Re: OMNI Quicklutch problem (Racermech)
it turns out this is normal. i just have to adjust the spring to 3-3.5 inches
S2Integra
Transmission & Drivetrain
Mar 20, 2010 06:42 PM
duyfash0
Mar 20, 2010 11:28 AM
Projekt93eg916
10
Mar 9, 2008 02:32 PM
boostmee
Feb 7, 2008 04:12 AM
VTechie
Jul 12, 2002 04:09 AM
