Oil Question
Old Oct 8, 2002 | 03:24 PM
Nighthawk GS-R's Avatar
New User
Default Oil Question
i know this is going to be stupid but where should the oil level be on the dipstick?
Old Oct 8, 2002 | 03:26 PM
Tomakit's Avatar
Default Re: Oil Question (Nighthawk GS-R)
Two holes/bumps on the bottom of the dipstick, correct?
Completely filled should get you oil up to the 2nd bump, that's 100% filled. Filled to the bottom bump means ~1qt low.
Anything in between is usually ok.
Tom
Old Oct 8, 2002 | 03:27 PM
B2FiNiTY's Avatar
2nd dot.
Old Oct 8, 2002 | 03:31 PM
New User
Default Re: Oil Question (Tomakit)
thats pretty good since i use mobile one and recently got an oil change. i was just driving and check engine light came on and computer wouldnt let me rev past 5000 rpm's. i knew right away what it was but when i pulled the dipstick out there was nothing. i just put two quarts in and its barely at the secon dot. how the hell could i have burned that much synthetic oil in a month and a half? i only drove 2000 miles or so.
Old Oct 8, 2002 | 03:33 PM
ragejed's Avatar
Check your oil after ur car sits for a while..All the oil is in the engine, not in the pan
Old Oct 8, 2002 | 03:34 PM
New User
i drove it everyday wise guy..............
Old Oct 8, 2002 | 03:43 PM
Tomakit's Avatar
who did the oil change...
Tom
New User
me
Old Oct 8, 2002 | 03:44 PM
ragejed's Avatar
Not being a wise guy. You said you saw the cel, so u got out and checked the oil. If you check the oil while the car is running, or right after you shut it off. Most of the oil is in the engine., cam lobes, etc
Old Oct 8, 2002 | 03:46 PM
New User
tru but i let it sit for 10 mins
Old Oct 8, 2002 | 03:49 PM
Tomakit's Avatar
Tomorrow morn, before you start the car, check the oil level. That should give you a better idea of if you are burning/losing oil somewhere, or if you've overfilled.
Tom
boyong07
Feb 24, 2008 07:47 PM
veilsides2000
Honda S2000
Dec 5, 2007 05:26 PM
digitalayon
Mar 13, 2005 07:55 AM
DVS Luder
Oct 24, 2004 01:55 PM
Tench
Jul 10, 2004 10:34 PM
