Honda S2000 Honda S2000
Oil question.
Old Nov 28, 2007 | 11:16 AM
veilsides2000's Avatar
Default Oil question.
Okay so my dumbass completely forgot about my Oil change interval because I had my windshield replaced and the sticker wne twith the old windshield.
I instantly went home to change my oil just to be safe and I know that i was at least a 1000miles over.
Once I changed the oil i decided to check and see how much oil came out the car. So i poured it into the quart containers and it only filled up 2 quarts.
I think i was close to 2000 miles over once i saw how thin the oil was.
My question is. Would thin oil equal less quarts because oil is usually thicker when first poured into the engine? It was 10w30 non synthetic oil. Does 2 quarts sound about right when the car takes 5?
Im not burning any oil or anything like that. The car runs like a champ and doesnt smoke except the little black puffs in between shifts.
I just switched to synthetic.
Old Nov 28, 2007 | 11:28 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Oil question. (veilsides2000)
was it changed cold?????
Old Nov 28, 2007 | 11:30 AM
Default Re: Oil question. (S@nt0s)
yea it was on the cooler side
Old Nov 28, 2007 | 12:32 PM
JLUDE01's Avatar
wow. Only 2 came out?!!!!
I'm surprised you didn't get an oil pressure light. The S2000 burns oil...that's just how the motor runs. I have to add at least a quart every 3,000 miles.
Check the oil level more often! And keep in mind on the S2000 dip stick you MUST wipe the stick off before re-inserting and checking the level! since it has crosshatch on the dip of the dipstick if you just let it settle cold and check the level it shows way more oil than is actually in there!
- JL
Old Nov 28, 2007 | 12:49 PM
Default Re: (JLUDE01)
Yea only 2 came out lol. The oil light would come on if i did some hard braking but other than that it stayed off.
Im guessing since the oil wasnt changed for so long it got thinner over time. That means that more can be added into a quart container as opposed to a container with thick oil.
Density difference?
The car doesnt really burn any oil lol. No blue smoke or anytime.
I just want to see if anyone else has experienced oil being low when changed and the oil being thin was the culprite for less oil.
Old Nov 28, 2007 | 01:04 PM
bky's Avatar
bky
Motor oil tends to get thicker over time, not thinner, as some ingredients cook off (think sludge). If the motor was cold, then I'd say you ony got two quarts out because you were low on oil, and left a lot of oil in the car because it was cold, espcially in the filter.
S2000's burn oil because of the massive intake vacuum that pulls oil from the valve cover through the PCV.
I wouldn't worry about begin over with regular dino-oil, and even less so with synthetic. Oil change intervals are very conservative, and in reality, average driving considitions are fine a lot more miles than the dealer or an oil-change shop will tell you.
Old Nov 28, 2007 | 01:17 PM
TL1000R's Avatar
I think this is a common thing. When I checked with the quys on H/T, they said it's normal for the S to use oil. Mine doesn't smoke either but it uses about a quart and a half every 3000 miles. I switched to Royal Purple at around 35kmi and it didn't change at all.
Old Nov 28, 2007 | 05:12 PM
ReddotsS2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veilsides2000 &raquo;</TD></TR><TR><TD CLASS="quote">Okay so my dumbass completely forgot about my Oil change interval because I had my windshield replaced and the sticker wne twith the old windshield.
I just switched to synthetic.</TD></TR></TABLE>
it ahppened to me when i first bought the car. i drove the **** out of it and it only drained 2 quarts, the car ran fine though.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TL1000R &raquo;</TD></TR><TR><TD CLASS="quote">I think this is a common thing. When I checked with the quys on H/T, they said it's normal for the S to use oil. Mine doesn't smoke either but it uses about a quart and a half every 3000 miles. I switched to Royal Purple at around 35kmi and it didn't change at all. </TD></TR></TABLE>
i also switched to royal purple and it made no difference, the car still goes through about a quart in about 2000 miles. i check my oils religously now and i live in vtec
Old Nov 28, 2007 | 08:04 PM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: Oil question. (ReddotsS2K)
were you on a big incline when you jacked it up?some oil could be sitting in the pan... next time warm her up and then drain out the oil... see where your at...
Old Dec 5, 2007 | 05:26 PM
gents97civ's Avatar
Thinner oil doesn't make a difference on the amount that you would get out. You were pretty low. Honda cars do tend to use some oil when you rip on them. You just need to get in a habit of checking the oil more often. Using a high quality oil, will help prevent the burnoff though. One other suggestion, its best if you change the oil with the car warm so that all of the old oil drains out.
highwhey
Nov 11, 2010 05:53 AM
boyong07
Feb 24, 2008 07:47 PM
digitalayon
Mar 13, 2005 07:55 AM
DVS Luder
Oct 24, 2004 01:55 PM
JSpecwest
Aug 6, 2001 02:48 PM
