Which oil pump to use?
Old Jun 22, 2005 | 02:29 PM
94lsboost's Avatar
Default Which oil pump to use?
The motor is a b18c1, not sure of the year...but I believe it is an obd1 motor. No crank or knock sensor. My question is, will the 96-01 pump (15100-P72-A01 ) work on the motor? I think I read that I may have to dremel out the plastic timing cover, but that's it. I just wanna make sure I don't get a pump that wont work, if the motor is a different year....
thanks
Old Jun 22, 2005 | 02:48 PM
shermanyang's Avatar
Default Re: Which oil pump to use? (94lsboost)
it should work just fine. and yes you will probably have to mod the bottom part of the plastic covering to fit. i'm running a 99 gsr water and oil pump on my 94 ls btw.
Old Jun 22, 2005 | 03:15 PM
94lsboost's Avatar
Default Re: Which oil pump to use? (shermanyang)
so you had to change the timing belt, but mine will be fine. I'll probably go with that one, I think it has provisions for the crank sensor, but I guess it doesnt hurt to not use it, correct?
Old Jun 22, 2005 | 06:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94lsboost &raquo;</TD></TR><TR><TD CLASS="quote">so you had to change the timing belt, but mine will be fine. I'll probably go with that one, I think it has provisions for the crank sensor, but I guess it doesnt hurt to not use it, correct?</TD></TR></TABLE>
yes i had to change the timing belt on mine because of the water pump change. and yes mine came with a crank sensor too but i didn't use it...didn't have a plug for it.
Old Jun 23, 2005 | 01:55 PM
94lsboost's Avatar
so you just leave the spot for the crank sensor empty? thanks again!
90 ef
Apr 23, 2009 12:51 PM
lovemyintegra1
Jul 13, 2007 07:44 PM
96MidoriHatch
Sep 15, 2004 04:54 PM
01h22lude
Jun 22, 2004 11:17 AM
b20ek
Jun 3, 2003 08:07 AM
