oil pump
Old Apr 23, 2009 | 05:40 AM
90 ef's Avatar
Default oil pump
i have a 94 gsr and i am rebuilding the motor. i bougt a kit and it came with a 96-00 oil pump. i am wondering whats the difference between the two and will it fit on my 94?
Old Apr 23, 2009 | 05:52 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: oil pump
It will fit but you have to trim the lower timing belt cover I believe.
All 96-01 Integras from the LS to the ITR use the same oil pump, but it is a bit different than the 94-95 because it was for an OBD2 engine, which included a crank fluctuation sensor, which is the reason you have to trim the lower timing belt cover.
Old Apr 23, 2009 | 12:51 PM
ruffrhyder's Avatar
96 and newer also has a hole to thread a bolt to mount the crankshaft position sensor.
Egpower88
Jul 21, 2009 02:51 PM
wwang924
Feb 23, 2006 11:10 AM
JDMoMo
Oct 18, 2005 07:52 PM
weraider30
Mar 7, 2005 05:34 PM
96MidoriHatch
Sep 15, 2004 04:54 PM
