Oil light flash.
Old Aug 13, 2007 | 06:50 PM
FOMULA91's Avatar
Default Oil light flash.
Just bought a 91 DA for my friend and the oil light keeps on flashing. The last owner told me that the oil was low but after we did a oil change, it still flashes. reset the ECU and disconnect the battery but nothing seems to work. The car runs fine but I don't want to miss anything up. Are the oil pressure sensor bad? Any info will be helpful.
Old Aug 13, 2007 | 07:03 PM
FOMULA91's Avatar
Default Re: Oil light flash. (FOMULA91)
Forgot to mention but there is no check engine light or cel code from the ECU.
Old Aug 13, 2007 | 08:05 PM
Sloshy's Avatar
either the pump is going bad.. or the sensor..
when do u get the light, when you're turning, hitting the brakes?
Old Aug 13, 2007 | 11:22 PM
FOMULA91's Avatar
Default Re: (Sloshy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sloshy &raquo;</TD></TR><TR><TD CLASS="quote">either the pump is going bad.. or the sensor..
when do u get the light, when you're turning, hitting the brakes?</TD></TR></TABLE>
It actually starts flashing as soon as the engine turn on.
Old Aug 14, 2007 | 01:53 AM
FOMULA91's Avatar
Default Re: (FOMULA91)
Anyone else?
Old Aug 14, 2007 | 03:27 AM
ls_efhatch's Avatar
wow another person with this problem...i have the same issue...mine wasnt the sensor or the pump...what i did was installed a new gsr oil pump,and took the sensor out and just installed a oil gauge 16 bucks..i hate gauges but i bit my lip and bought one...just as a test hook one up and if u got good oil pressure ur fine.if not then change the pump...
Old Aug 14, 2007 | 07:52 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I had this problem several years ago, oil light flashing when car was on. At the same time, the battery light would come ON when I turned the car OFF.
I did extensive study of the wiring diagrams in both my Helms and Haynes manuals (it's a good idea to have both), and found that the only thing in common between the oil pressure sensor and the charging system was a connection to the alternator.
I ended up replacing the alternator, and both problems were fixed.
Weird I tell you, weird stuff can happen when there's a problem with the charging system.
Old Aug 14, 2007 | 01:50 PM
FOMULA91's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls_efhatch &raquo;</TD></TR><TR><TD CLASS="quote">wow another person with this problem...i have the same issue...mine wasnt the sensor or the pump...what i did was installed a new gsr oil pump,and took the sensor out and just installed a oil gauge 16 bucks..i hate gauges but i bit my lip and bought one...just as a test hook one up and if u got good oil pressure ur fine.if not then change the pump...</TD></TR></TABLE>
Cool, thanks for the useful info. I'll tell my friend and try it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I had this problem several years ago, oil light flashing when car was on. At the same time, the battery light would come ON when I turned the car OFF.
Weird I tell you, weird stuff can happen when there's a problem with the charging system.</TD></TR></TABLE>
Yeah I was a little confuse when I 1st saw the light flash even the oil level was at the right point.
Once again, thanks for the info guys
whereiscarmensandiego
Oct 25, 2008 01:40 PM
HONCORD
May 28, 2006 08:11 PM
LsVtakYO
Jan 11, 2006 12:14 PM
Cashflo
Apr 25, 2003 07:40 AM
Solipsist
Nov 18, 2002 03:30 PM
