oil burning problem
SO im here again searching for more help n greater minds than mine haha.
my poor man type r build finished about 2 months ago. (all stock p72 rods n pistons. b16 head with all new valve seals n re seated valves. )
i drove it for 110 miles yesterday n burnt 1 quart of oil. i turn the car on let it run for about 20 minutes shyt it off remove the plugs n with a light i look into the cylinder n there is oil on top of the cylinder . not filled but noticeable.
once again i run into a problem n im dumbfounded . new seals new rings honed blocked new HG n dowel pins, valves re seated. arp head studs n this thing is burning oil. the only thing i think of is valve guides but there wasnt any play on the valves when i tried to check em.
almost forgot compression test result was 255 on all cylinders
IM CLUELESS at this point any suggestion comments will b greatly appreciated HT.
Some common reasons for this:
Rings installed upside down,
missing or damaged intake valve-guide oil-seals (I know, but check anyway),
ring gaps lined-up instead of staggered,
bore not round (or damaged on assembly),
rings not round (or damaged on assembly),
bore surface not correct (or damaged on assembly),
excessive bore/piston clearance,
excessive ring-groove clearance.
Time for a teardown.
yay!!! =[ lol i had everything that needed machine work done by a actual machine shop so i was expecting their hone/cylinder wall job would b acurate but guess even the pros can mess up then .
thanks for the info. great responce. im about to do a leak down test tomorrow to see what exactly could be n guide me the direction or directions i need to go.
