D16a6 burning oil! Help please
Old Feb 10, 2016 | 02:53 PM
Brian Deane's Avatar
Default D16a6 burning oil! Help please
Hi all I got a 88 crx si and it's got a nice oil burning problem. Tested compression and it's good 152 152 154 152. Pcv valve is good just put new valve seals in and reseated all the valves and a new head gasket. I was thinking one or more of my oil returns in my head are clogged causing oil to fall thru the valves when they open so does anyone have a picture of where they are located? Any help is awesome
Old Feb 10, 2016 | 02:57 PM
v4lu3s's Avatar
RTFM
Default Re: D16a6 head oil return hole locations?
Oil in the head cannot get to the valves with good valve stem seals.
Probably just worn oil control rings.
Old Feb 10, 2016 | 03:01 PM
True now that I think about it and I thought of that too I tried the mmo soak for 2 days nothing. Tried Berryman b12 soak for a while and nothing really also I put in 20w 50 and it burns just as much as it did with 10w 30 I also have a decent amount of mmo in my tank would that cause smoke? I'm sure it would but not this much I put maybe 3 cups into 4 gallons
Old Feb 10, 2016 | 03:04 PM
I also took my header off and saw some oil or what seemed like oil on the ports
Also there's constant water coming from my exhaust tip
Old Feb 11, 2016 | 07:09 AM
v4lu3s's Avatar
RTFM
Default Re: D16a6 burning oil! Help please
Has the engine ever over heated?
VvPeachyvV
30
Nov 29, 2005 04:42 PM
SpeedMachine
Apr 29, 2005 12:27 AM
thehondaguru
Jun 9, 2004 06:09 PM
93LSivic
May 27, 2002 10:27 PM
