Off idle stumble.WTF?
Old Sep 9, 2003 | 09:06 PM
Green94GSR's Avatar
Default Off idle stumble.WTF?
While my car is at idle or low rpm and I step on it, it severely falls on its face for a second, then revs. I have a Walbro 255HP fuel pump, stock fpr, ZEX plugs, NOS NOSzzle direct port nitrous(NOT using at idle), and timing retarded slightly. I couldn't tell exactly where I was timing this bastard, could only see the red mark(16) and white mark(TDC) so I guessed where 3 degrees was. Anyone know if this is a timing/cold plug issue or fuel issue? Maybe a NOSzzle issue?
Old Sep 9, 2003 | 09:08 PM
91tegrals's Avatar
could be a vacume leak any fumes maybe to much fuel bogging the motor....
Old Sep 9, 2003 | 09:13 PM
Green94GSR's Avatar
Good call, I have been thinking that since I originally had a bad leak around NOSzzles. modified fuel rail brackets and tightened and thought I had the vacum prob fixed. Tried starting fluid on the NOSzzles and idle didn't change so I thought I was good. How can I narrow it to a vacum leak/find the leak? I had a lot of stuff apart.
99black_em1
Engine Management and Tuning
Dec 21, 2011 02:33 PM
gooberwolf
Apr 15, 2004 09:02 AM
BoostedD15B7
Nov 12, 2003 05:53 PM
gooberwolf
Aug 6, 2003 01:59 PM
