Odometer issue, won't work
Old Aug 25, 2013 | 03:03 PM
redturbo0's Avatar
Default Odometer issue, won't work
Tried two clusters and speedo works but odometer won't... I can't figure out why! Unless both clusters are broken, I dunno. Car is a 96 integra RS
Any advice would be great, thank you!
Old Aug 26, 2013 | 05:08 AM
aw614's Avatar
10 Year Member
Loved
Default Re: Odometer issue, won't work
the speedometer still works?
Old Aug 26, 2013 | 05:23 AM
gsrbanger's Avatar
VSS?
Old Aug 26, 2013 | 06:16 AM
fcm's Avatar
fcm
Old Fart
If the speedo works, I can't see it being anything but the cluster itself. 94
Old Aug 28, 2013 | 02:02 PM
TheIVJac|{al's Avatar
This literally just happened to me yesterday as well. I think what happens is that a pin or whatever is inside the cluster, gets sticky after a while with the old grease and
doesn't unlock.
How I fixed it.
While I was driving, I pressed the reset button again and it started working. If it doesn't work right away, try pressing it in different manners. Push in and quickly release so it snaps, push in slowly and release slowly, etc... Try different ways and hopefully it ends up working properly again.
- Aaron
Old Aug 28, 2013 | 06:44 PM
aw614's Avatar
10 Year Member
Loved
doesn't unlock.
How I fixed it.
- Aaron
Im going to have to try that again, I've done the push in and quick release and it started working on my 97 LS, next day it stopped working. I sort of punched the odo before it worked, next day it stopped. I had it working for 1000+ miles earlier this year without resetting the trip odometer, then my sister drove it, got gas, reset the odo and it has sporadically worked since.
Stopped at 229k reported miles heh, probably has like 240 to 250k realistically.
Old Aug 29, 2013 | 03:35 PM
Not exactly the same as an Integra but this was done on a CRX.
*DO NOT USE FOR FELONY CRIMINAL TAMPERING.
How to open up Odometer on CRX
If you could do something similar to this on the Integra cluster and write a how-to, that would be awesome! Good luck.
- Aaron
Old Sep 2, 2013 | 05:33 AM
redturbo0's Avatar
I really don't wanna mess up my cluster and rip it apart, haha... I tried the button thing, it moves slightly, but that's it.
Old Sep 2, 2013 | 05:59 AM
redturbo0's Avatar
a guy on this forum, http://tl.acurazine.com/forums/showthread.php?t=757772 seems to think that its a problem with solder connections... what are the odds two clusters have bad connections? I guess its worth checking out though.... I mean I do have an extra cluster now, but it doesn't read water temp... so if I f it up, who cares, lol
Old Sep 2, 2013 | 06:08 AM
redturbo0's Avatar
that came up when I searched integra odometer not working on google.... I didn't realize it was for a tl
Old Oct 6, 2013 | 08:03 PM
SolusEM1's Avatar
my odo also does not work... trip works, speedo works, everything works but the odo... 2000 civic si though
Mugen'dAccord
Jul 16, 2009 08:11 PM
Turbo Dan
May 11, 2008 02:26 PM
redboost10
May 1, 2008 09:22 AM
civiccpedx
May 18, 2007 06:56 PM
