Obdo to obd1 distributor?
Old Aug 27, 2012 | 11:19 AM
SlowB20z's Avatar
Default Obdo to obd1 distributor?
Hey folks i got a 91 teg w/b20. The dizzy is starting to fry so i jumd on ebay & i keep seeing obdo to obd1 dizzy wire harness, is there a benefit to this like reliability by running a obd1 dizzy instead of a obd0 dizzy & if you did does this also mean you have to switch to obd1 ecu?
Old Aug 27, 2012 | 01:29 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Obdo to obd1 distributor?
Yes to run the obd1 distributor youll need to run an OBD1 ECU
Old Aug 28, 2012 | 08:42 AM
Double Agent's Avatar
RyWire and similar companies sell full conversion kits to go to OBD1. You'll have a lot more tuning capability. You'll probably see an improvement in power and drivability since you're swapped.
Old Sep 3, 2012 | 06:30 PM
SlowB20z's Avatar
Ok well let me ask you this then, from the pictures of the harness it looks as though the harness plugs right in to the ecu & all the wiring is for the distributor....correct?
This going by the harness from "Phearable"
ryanangelo212
Mar 18, 2013 12:23 AM
white92teg
Feb 12, 2010 01:09 PM
crxfreak1117
Feb 27, 2008 09:32 AM
Ruby Civic
Dec 11, 2003 04:07 AM
Norcalstoppy
Jul 13, 2002 08:02 AM
