obd2a/obd2b
Old Nov 4, 2007 | 03:09 PM
Fat Chick Magnet's Avatar
Default obd2a/obd2b
Can i run a obd2a motor with a ob2b ecu without throwing any codes? If not, does anyone know what i have to convert on the motor to run a obd2b ecu?
Old Nov 4, 2007 | 05:45 PM
ttt
Old Nov 4, 2007 | 08:24 PM
nokturnal_munkeeboy's Avatar
Default Re: obd2a/obd2b (dc2rtek)
you can use a obd2a to obd2b jump harnes you should be fine.
Old Nov 4, 2007 | 08:43 PM
Default Re: obd2a/obd2b (nokturnal_munkeeboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nokturnal_munkeeboy &raquo;</TD></TR><TR><TD CLASS="quote">you can use a obd2a to obd2b jump harnes you should be fine.</TD></TR></TABLE>
Yeah i know about that, but I'm just curious to know about smog in the future.
Old Nov 7, 2007 | 08:01 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2rtek &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah i know about that, but I'm just curious to know about smog in the future.</TD></TR></TABLE>
my car will never pass smog with upgraded cams. thanks for info.
/thread.
Old Nov 8, 2007 | 12:29 PM
obd2 and b are pretty much the same. what cams are you plannin to run with
Old Nov 8, 2007 | 12:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nokturnal_munkeeboy &raquo;</TD></TR><TR><TD CLASS="quote">obd2 and b are pretty much the same. what cams are you plannin to run with</TD></TR></TABLE>
Jdm itr motor supertech dual valve springs/portflow retainers with either skunk2 pro1's or rocket motorsport cams. im still doing some re-search.
Old Nov 8, 2007 | 12:44 PM
i have buddy club head package with hi compression flat surface valve, with jdm os itr piston and i pass smog with it
Old Nov 8, 2007 | 12:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nokturnal_munkeeboy &raquo;</TD></TR><TR><TD CLASS="quote">i have buddy club head package with hi compression flat surface valve, with jdm os itr piston and i pass smog with it</TD></TR></TABLE>
really? but I'm also concerned about the whole obd2a/obd2b situation. I mean i know with any obd2 they plug in wires some where under the dash to smog the car. I'm sure if all my sensors are working and i have a catalytic converter on it should pass smog.
edit: and obviously exhaust system being stock or carb legal parts under the hood.
Old Nov 8, 2007 | 12:49 PM
if you make outside engine bay look stock, they dont kno what inside ur motor.it should pass, the only problem i had was i had a bad cat.
Old Nov 8, 2007 | 12:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nokturnal_munkeeboy &raquo;</TD></TR><TR><TD CLASS="quote">if you make outside engine bay look stock, they dont kno what inside ur motor.it should pass, the only problem i had was i had a bad cat.</TD></TR></TABLE>
Oh i also have buddyclub spec 2 exhaust i don't think they will approve that haha.
but i obviously have the stock exhaust. but overall do you run your car with a cat or test pipe after smog?
Old Nov 8, 2007 | 05:23 PM
i ran it with the stock cat, so when they put the new one on i pass with flyin colors, exhaust system doesnt matter as long it a cat back exhaust system , aftermarket exhaust doesnt effects the smog testing
Old Nov 8, 2007 | 05:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nokturnal_munkeeboy &raquo;</TD></TR><TR><TD CLASS="quote">i ran it with the stock cat, so when they put the new one on i pass with flyin colors, exhaust system doesnt matter as long it a cat back exhaust system , aftermarket exhaust doesnt effects the smog testing</TD></TR></TABLE>
so rocket motorsport m22x or skunk2 pro 1's?
Old Nov 8, 2007 | 10:57 PM
if i was you , i would put those cams in after you pass smog, when you run those cams you have to have a chipp ecu to run those cams, it not goin to work with stock ecu
Old Nov 11, 2007 | 10:34 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nokturnal_munkeeboy &raquo;</TD></TR><TR><TD CLASS="quote">if i was you , i would put those cams in after you pass smog, when you run those cams you have to have a chipp ecu to run those cams, it not goin to work with stock ecu</TD></TR></TABLE>
oh yeah my smog is long gone for another 2 years or so. i don't even think ill have my car for another 2 years.
Old Nov 12, 2007 | 08:10 PM
oh ok
Old Jan 22, 2008 | 10:52 AM
Lbenner05's Avatar
Whats the difference between obd2a and obd2b i need a usdm ecu for my 99 integra and everyone keeps telling me i have to use a obd2b why wont the a work
emaka9
31
Oct 9, 2008 07:15 AM
redDAinteg
Dec 17, 2006 01:33 PM
twisted_jdm_b16
Jul 25, 2006 08:57 AM
TurboGS-R
Feb 24, 2006 12:07 PM
bomber
Sep 21, 2004 09:14 AM
