obd2 injector problem....
Old Aug 15, 2010 | 03:26 PM
BB6matik's Avatar
Default obd2 injector problem....
i have a 95 b16 head/ 94 gsr block using obd1 p72....car came with obd2 injector clips and obd2 injectors....wanna know how to put the obd1 injectors on....will i need to change the clips? if so, are the wirings going to be the same if i just cut and replace it with the obd1 clips???
Old Aug 15, 2010 | 03:44 PM
lynxs1981's Avatar
Default Re: obd2 injector problem....
The injectors should fit the way they are.
Old Aug 15, 2010 | 05:07 PM
mouab18c1's Avatar
If you want obd1 injectors, you will need to get obd1 injector clips cut and rewire everything. Fairly simple. Trying to shave the obd2 clips to fit the obd1 injectors is a stupid idea....
Old Aug 15, 2010 | 05:12 PM
paton5g's Avatar
x 2.
The clips can be replaced by cutting the old ones off. Use solder and be sure to use shrink tube. These are connections that MUST stay intact.
Good luck.
Old Aug 15, 2010 | 05:47 PM
BB6matik's Avatar
had a feeling that i have to solder too...well okay...thanks!
Old Aug 15, 2010 | 05:54 PM
lynxs1981's Avatar
If you're running an obd1 ecu in an obd2 car, you can keep the injectors the way they are.
Hondatypr636
Aug 7, 2011 08:02 AM
jewpont
Jul 11, 2009 01:24 PM
RBNightMare
Feb 13, 2007 11:50 AM
EKB18BPR3
May 6, 2005 08:07 AM
chet
Nov 26, 2003 08:56 PM
