OBD I GSR code reading
Old Dec 14, 2014 | 09:56 PM
95gsr@530's Avatar
Default OBD I GSR code reading
I have a 95 gsr throwing a code. I was told it was a VTEC solenoid code by the previous owner. He isn't extremely mechanically inclined but he was told by someone more knowledgeable than he. I'm only somewhat familiar with OBD1, and I'd like to check and clear the codes the proper way. I know there's a code, long blinks equal ten and quick blinks equal one. add em up. But I don't know what the numbers correspond to. Where do I find this info, and what is the best way to get my stock 95 gsr to display the codes? All and any information is appreciated.
Old Dec 14, 2014 | 10:24 PM
B_Swapped93's Avatar
Default Re: OBD I GSR code reading
Check Engine Light Codes: Honda 1990-1995 obd1 code retrieval
google search took 2 seconds this is the one I used to use when I was obd1
Old Dec 15, 2014 | 02:35 PM
95gsr@530's Avatar
thanks man, what's the best way to clear the code once I think I've fixed it?
Old Dec 15, 2014 | 02:57 PM
undo the negative battery terminal for a few mins or pull the 15A fuse from the engine bay fuse box.
Old Jan 6, 2015 | 10:59 PM
95gsr@530's Avatar
thanks for the advice, the code was 21 and 22. followed the wiring, someone, somewhere along the line cut the wires to never reconnect them again. after wiring it my self check engine light went off and vtec now works!
RunsWithBorders
Jun 12, 2018 02:54 PM
jonyi27
Acura TL, RL & ZDX
Jan 22, 2017 12:53 PM
0ne-Cam
14
Aug 20, 2009 06:58 PM
lmblf8
Sep 19, 2004 11:11 AM
97 silverbullet
Jan 13, 2004 06:02 PM
