obd-0 codes
Old Jul 1, 2006 | 10:52 AM
Devo94ac's Avatar
Default obd-0 codes
how do you check for codes on an obd-0 pg7 ecu, its in an 88 integra.
Old Jul 1, 2006 | 04:16 PM
Devo94ac's Avatar
Default Re: obd-0 codes (Devo94ac)
some one knows
Old Jul 1, 2006 | 04:52 PM
91maroonGoon's Avatar
if i remember you have to insert the key into the ignition, then turn over to access then off 5 times in a row, then the check engine light should blink for the corresponding code.
Old Jul 1, 2006 | 08:26 PM
d16vtecx's Avatar
Default Re: (91maroonGoon)
just turn the key over till the dash lights come on
then look at the blinking light on the ecu
the flashes are either short or long
short=1 long=10
example: long short short code 12
short short short short short short short short short code 9
long long short code 21
hope this helps
Old Jul 2, 2006 | 07:41 PM
Devo94ac's Avatar
Default Re: (d16vtecx)
thanks for all the help.
tf87
Mar 7, 2019 04:00 PM
jw 1
Jul 6, 2009 06:44 AM
drift_n_shift
Mar 17, 2008 01:27 AM
Coltmorris
Nov 2, 2006 07:15 PM
