ob2 to ob1
Old Nov 19, 2006 | 08:42 AM
dc2leftovers's Avatar
Default ob2 to ob1
got a 97 integra ls and am looking for another motor to build while still keeping the one in the integra for a daily driver. ive found an ob1 b18 ls but what do i need to change for that motor to work with my ob2 integra
Old Nov 19, 2006 | 08:49 AM
SlammedDC2's Avatar
Semper Fidelis
Default Re: ob2 to ob1 (dc2leftovers)
Just so you know it is OBDI and OBDII. I thought your 97 would be OBDI
Old Nov 19, 2006 | 08:55 AM
Azn Kenny's Avatar
96 and up were all OBD2.
Old Nov 19, 2006 | 08:56 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (Azn Kenny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azn Kenny &raquo;</TD></TR><TR><TD CLASS="quote">96 and up were all OBD2.</TD></TR></TABLE>
This was required by Federal law.
Old Nov 19, 2006 | 08:58 AM
SlammedDC2's Avatar
Semper Fidelis
Default Re: (Dogginator)
Oh well, there you go. I can't keep up with all that stuff.
Old Nov 19, 2006 | 09:23 AM
95 integra's Avatar
Default Re: ob2 to ob1 (SlammedDC2)
You could convert the sensors on the OBDI motor over to OBD II. You can also run OBD I sensors and harness and then run a OBDIIa to OBDI conversion harness and OBD I ECU.
Old Nov 19, 2006 | 04:25 PM
Default Re: ob2 to ob1 (95 integra)
i was told that i gotta take the alternator off my obd2 ls and use it on the obd1 motor so my plugs would match up and then i would just need an obd1 ecu and conversion piece for the ecu and something about a sensor on the tranny on a obd2 that aint on the obd1 but i can run any b18 tranny right?
Old Nov 19, 2006 | 06:10 PM
95 integra's Avatar
The alternator, injectors, distributor, and probably some other **** is all different and will have to be converted over to use your OBD II harness....including the crank position sensor on the oil pump. You can use your stock ecu with no modifications if you go this route.
Old Nov 19, 2006 | 06:35 PM
ok so it will be relatively simple being that i have an obd2 ls motor to ****** parts from? they interchange completely until it comes to the plugs right?
Old Nov 19, 2006 | 07:13 PM
95 integra's Avatar
The only difference in the actual motor/assembly is the oil pump....it has the extra place for the crank position sensor.
Old Nov 20, 2006 | 08:49 AM
ok so i should be able to just create a port or something for the crank position sensor?
hondaeg5
Engine Management and Tuning
Oct 27, 2008 09:10 AM
GR_DC2
Dec 26, 2005 05:53 AM
TheBobFather
Oct 11, 2005 06:38 PM
TeknoGroover
Apr 10, 2005 03:36 PM
quicksol95
Mar 11, 2004 09:08 PM
