O2 Sensor
Old Apr 12, 2004 | 03:23 PM
VTECPowerdSi's Avatar
Default O2 Sensor
I have a 2000 civic si with a JDM B18C swap with OBDII sensors switched over and am running the B16 stock ecu. when i did the swap the check engine light stayed on and when i checked the code it was the O2 sensor. So i bought an OBD2 to OBD1 conversion harness and b18c ecu and the light is off but i am getting horrible gas milage, anyone know what to do.
Old Apr 12, 2004 | 05:04 PM
IVI's Avatar
IVI
Default Re: O2 Sensor (VTECPowerdSi)
get it tuned.
Old Apr 12, 2004 | 05:12 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
What year is your swap? I have a '99 JDM B18c-R OBD2 swap with the USDM R ECU and got the o2 sensor code but I found out my cat was clogged. But i swithced to a JDM R ECU and no code because it doesn't read the 2nd o2 sensor.
Old Apr 13, 2004 | 01:32 PM
Default Re: O2 Sensor (Gee3)
the motor is like a 94 i think, but the sensors were swapped over from my b16a2 to this motor
Yajhershey
Feb 1, 2014 03:04 PM
MattNYC
Nov 22, 2010 08:22 AM
oem_cg3
Aug 9, 2008 08:09 AM
743
Apr 30, 2004 11:06 AM
92Lude
Oct 3, 2002 07:14 PM
