o2 sensor help
1 Post
o2 sensor help
I put some anti-seize lub on the thread part of the o2 sensor, that wouldnt harm it would it?
would it cause me to have an check engine light?
Re: o2 sensor help (thrty8street)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street »</TD></TR><TR><TD CLASS="quote"> I put some anti-seize lub on the thread part of the o2 sensor, that wouldnt harm it would it?
would it cause me to have an check engine light?</TD></TR></TABLE>
No. The anti-seize will keep the O2 sensor from backing out of the header/downpipe while driving from the vibration (which I've had happen before... sucks because you get a nasty sound like your exhaust broke and you lose power right away). You may want to make sure that you didn't hit/bend the housing or make it come loose. I've seen O2 sensors go bad and throw a code when somebody hit it with a wrench while tightening it back up. If you can twist and/or wiggle the housing of the O2 sensor while tightly screwed into the header, then it's busted and needs to be replaced.
Lude_with_an_H22_Attitude
11-03-2005 02:22 PM
