O Ringing!?!?
ok.. everyone said i should get oring for my block because of high compression i want to run.. i am assuming o rings are with the head gasket but i dont know where? .. what exactly do they do -
how much would it cost to get done - could i do it myself?
will it make that much of a difference?
o rings for your block because of high compression? huh? im confused.
if you want to run high compression.. im guessing that youre doing an all motor setup. i assume they might have told you to get rods, pistons, and rings.
O-ring 's are machined into the top of the deck or arround each cylinder to provide a better seal between the block and head gasket. usually it's copper wire that is inserted into the machined grove.
