Notchy Shifting?
Old Oct 26, 2010 | 09:05 PM
Original.'s Avatar
Default Notchy Shifting?
I have a manual 97 Integra and I've been noticing notchy shifting lately. I have 169,000 miles on the car as of right now. I don't drive the car hard or anything, 99% of the time I drive like a grandma. When I first got it, the shifts were really smooth. I'm not sure if the tranny fluid has been changed out yet but I will be doing this ASAP. Even when the car is off, the shifting is still pretty rough. For example, when I shift from 1st to 2nd it seems as if it stops in the middle then goes into 2nd. I had 2 bad experiences when stopped at a red light. I clutched in all the way to go into 1st but it wouldn't budge, I tried 2nd and it didn't go all the way in and it grinded. I had to put it in neutral, pump the clutch and put it back in 1st. Any ideas?
Old Oct 27, 2010 | 06:35 AM
SuzukaBlueAP2's Avatar
Default Re: Notchy Shifting?
How many miles were on it when you bought it?
Changing the transmission fluid is a good start. Flushing the clutch fluid wouldn't be a bad idea either.
Old Oct 27, 2010 | 07:17 AM
fv8s's Avatar
how old is the clutch? it may not be fully engaging causing the gear changes to be a bit harsh. i recommend pennzoil syncromesh for trans fluid
Old Oct 27, 2010 | 07:38 AM
Original.'s Avatar
154,000 I believe. Yeah 2 years owning this car and I only put 15,000 miles on it lol. I'm sure the previous owner didn't change any fluids at all. I'll more into this.
Not sure how old the clutch it. It feels pretty light compared to all my other friend's cars. I heard really good things about Pennzoil, MTF, Redline, and GM. Not sure which one is superior though.
Another thing I noticed is that when I filled up on 87 Chevron gas, the shifting is quite smoother. It only lasts for a couple of days however.
Old Oct 27, 2010 | 07:54 AM
dudesitsjdm's Avatar
Honda mtf should do the trick.Sound's like you might just need a tranny fluid change if you still have the prob after i would look into the clutch.How come you do not use 91 it is way better for the car.
Old Oct 27, 2010 | 10:03 AM
ruffrhyder's Avatar
If it's a stock LS, there's no need for 91 octane. Dirty/old tranny fluid wouldn't explain why after pumping the clutch pedal a few times the OP can get the tranny into gear. It sounds more like a faulty hydraulic system.
Old Oct 27, 2010 | 10:16 AM
OOO because i thought tranny fluid helped it go into gear.Sorry op i was wrong.
Old Oct 27, 2010 | 10:35 AM
fcm's Avatar
fcm
Old Fart
I agree the first thing to change is the clutch hydro fluid, [flush and replace] if that makes no diff. then I would replace the transmission fluid, if no improvement then replace the clutch, 169,000 miles on a stock clutch is a lot, [if it's still stock/OEM].
Start with the easiest/cheapest, [clutch hydro fluid] then the next cheapest, tranny fluid/oil] then the more expensive clutch replacement.
It can't hurt to do the hydro fluid and tranny fluid/oil anyway. 94
Old Oct 27, 2010 | 11:26 AM
1998GsRIntegra's Avatar
My oem clutch ended up lasting around 175,000mi before it needed to be changed. Although it did come out in peices. Lol. If you end up changing your transmission fluid see if you can find friction modified gm synchromesh. The gm dealership in my area still had quite a few dozen cases in stock according to the parts guy, even though it was discontinued a while back.
Old Oct 27, 2010 | 11:42 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
GM Synchromesh Friction Modified is superior to the Pennzoil stuff (which is NOT friction modified). If you can't find the GM stuff, I recommend the newer formulation of Honda MTF.
Old Oct 27, 2010 | 06:56 PM
Original.'s Avatar
I was looking at Team Integra's DIY on how to change the tranny fluid and he used Redline. IDK where I can buy that stuff, but if anything I'll get MTF or GM. If I can find it. Lets just hope its just the tranny fluid if anything. I'm no expert when it comes to mechanic work, but I sure wish I was.. Thanks for the advice guys.
Old Oct 27, 2010 | 07:00 PM
Just run down to your local gm dealership. They will have regular synchromesh in stock. If you are lucky they will have some friction modified synchromesh. If nothing else you cen get it from ebay. It is worth it.
Old Oct 27, 2010 | 07:10 PM
CrackerJackToy's Avatar
Just try changing the fluid, and even adjust the clutch pedal. This can work wonders.
Old Oct 28, 2010 | 03:56 PM
Cortez_h's Avatar
Idk if it's just me but the new honda mtf fluid once warmed up brings on the notchy shifting.
Old Oct 28, 2010 | 11:08 PM
TOO MUCH TORQUE's Avatar
i find that most notchy shifts are due to "lazy" shifts. its all about timing...but fluid helps tons too.
i run amsoil syncromesh in my car.
this fluid made the shifts precise and gives it a positive firm feeling
pennzoil syncromesh
mushy feeling but smooth
honda mtf
firm and kind of notchy.
amsoil is my choice!
I agree with a poster above with flushing the clutch line first. If you can, use the vacuum tool...i believe its much more effective than the standard pump the clutch method. higher chance to let air in with pumping the clutch pedal.
Old Oct 29, 2010 | 03:53 PM
Community Builder
I can't comment on if it's any easier or better using a vac pump to bleed the clutch line, but it's impossible to let air into the clutch line as long as you keep the reservoir from running dry, and you keep the tube on the bleeder screw submerged in fluid. You're really no more or less likely to let air into the line with either method if you keep fluid in the reservoir. If you let it run dry you'll introduce air no matter which method you use.
Old Nov 1, 2010 | 08:05 AM
vrrodri's Avatar
What fluid did you use for the clutch MC after flushing it?
Old Nov 1, 2010 | 08:14 AM
Presto800's Avatar
Honda MTF did miracles for me back when I had my Integra. It was like shifting a butter knife through a tub of butter after the flush.
Old Nov 1, 2010 | 05:08 PM
Community Builder
Been using Valvoline DOT III Synthetic brake fluid for years for brakes and clutch.
Old Nov 2, 2010 | 09:30 AM
lsturbo33's Avatar
Amsoil syncromesh. It made my 3rd gear stop grinding. With honda mtf it would grind.
itr1244
Sep 29, 2014 12:52 PM
junk95civ
Apr 28, 2010 05:54 PM
DC5Danny
Jan 21, 2008 08:36 AM
lude98SH
Oct 25, 2005 09:10 AM
Toretto
May 12, 2003 01:02 PM
