NOISE
Old Apr 28, 2004 | 07:52 AM
96civich22's Avatar
Default NOISE
hey guys i have a 94 teg ls, and when i bought it about 5 months ago everything was fine, no engine noise no noise at all. but now all of a sudden about a month ago my driver side rear break is SCREAMIN. what it sounds like is when you need new pads that screatchin noise when the brake is applied, but this noise is constant , i dont have to apply the brake. the noise is very loud. i have checked the rotors (no grooves, very smooth) i have checked the pads (like new, plenty of meat). so i need to know what else could it be, or what are some solutions.
Old Apr 28, 2004 | 08:07 AM
LowTEC SaiMike's Avatar
Default Re: NOISE (96civich22)
does it go away after u drive a while ..... or does it still do it all the time ?
Old Apr 28, 2004 | 08:45 AM
96civich22's Avatar
Default Re: NOISE (BomBoi)
all the time, and its even worse when i back up, its louder and its a deeper sounds not as high pitch as going forward
Old Apr 28, 2004 | 09:00 AM
greaseball's Avatar
could be wheel bearings. mine is doing it right now too and i need new wheel bearings.
Old Apr 28, 2004 | 11:09 AM
96civich22's Avatar
Default Re: NOISE (greaseball)
how hard is that to replace on a rear wheel
Old Apr 28, 2004 | 11:12 AM
slomofo's Avatar
GDD Member
Could be the dustshield behind the rotor rubbing on the inside.
Old Apr 28, 2004 | 11:13 AM
Sack Master's Avatar
Could also be the dust shield. Make sure thats not rubbing, and also spray some brake cleaner in there. If it's not a wheel bearing, it would suck to spend all the time and money replacing it. Check the easy stuff first. Good luck.
Old Apr 29, 2004 | 12:36 PM
96civich22's Avatar
Default Re: NOISE (Sack Master)
well its not the dust shield so i guess its the wheel bearing??? i found one at the dealership but they seel the complete hub for it, not just the bearing nd its going to cost me like $190 how long of a process is this to do
Old Apr 29, 2004 | 12:39 PM
3 plus 1's Avatar
You need to check the inside of the rotor aswell (the side you cant see). Your other side might be fucked or the pad might be worn to nothing. Also, those bolts that the caliper slides on sometimes get sticky and freeze up. Could be holding the pad to the inside of the rotor.
Old Apr 29, 2004 | 12:40 PM
I just took a bottle of cuervo down to my buddys machine shop when I replaced my hubs and bearings. I would imagine it's not to expensive. I did however take my knuckles off for him.
Dackonn
Suspension & Brakes
37
Mar 2, 2025 02:16 PM
HC4
Honda CR-V & Element
Jul 4, 2019 05:45 AM
ch0baca
Sep 21, 2009 01:31 PM
Mr Boston
Dec 27, 2002 03:37 AM
