no spark
Old May 3, 2009 | 12:33 PM
1badcrx's Avatar
Default no spark
my car was running very spotty, bogging down. then one day it just died all together and wouldnt start back up. It was giving me a 21 code. vtec solenoid, i thought it was the distributor... so i cleaned out the solenoid and it still wouldnt start. so i checked the spark, none at all. i had the coil and the igniter tested. the igniter was bad so i purchased a new one and still no spark. i put a new rotor cap and distributor cap on, still no spark. At this point i'm lost and completely frustrated. Could it be that i just need to repalce my distributor?
Thanks
Old May 3, 2009 | 01:53 PM
Jimmy's Avatar
Global Moderator
Default Re: need some help..
https://honda-tech.com/forums/acura-integra-6/creating-new-topic-choose-subject-specific-title-not-help-me-asap-2477272/
Old May 3, 2009 | 08:39 PM
Jimmy's Avatar
Global Moderator
Where did you purchase the new ignitor? Test the 'new' one.. it could be dead.
this thread has ignition related info in it.
https://honda-tech.com/forums/acura-integra-6/1994-2001-gen-3-all-general-information-specifications-2306055/
Also retest the ignition coil just to be 100% sure.
Old May 3, 2009 | 09:47 PM
210southstar's Avatar
Default Re: no spark
Thats how mine sounded n yes it was tha dizzy
Old May 4, 2009 | 06:13 AM
1badcrx's Avatar
i purchased the ignitor through autozone, and i had them retest it after putting it in. the coil read properly in ohms. i know it could still be wrong. but idk if i should go ahead and try a new coil or just try replacing the dizzy...
Old May 4, 2009 | 06:55 AM
s2kmugenpower's Avatar
Do you have power to the dizzy? if yes then just replace the dizzy itll be less trouble
Old May 4, 2009 | 08:43 AM
1badcrx's Avatar
i don't see how i wouldn't be getting power to the distributor. is there any way to check for power?
Old May 4, 2009 | 12:55 PM
1badcrx's Avatar
Old May 4, 2009 | 08:51 PM
1badcrx's Avatar
so dizzy it is then?
Old May 4, 2009 | 09:12 PM
jhammond_82's Avatar
Reject Papi
give it a try. thats what i would have to guess on too.
Old May 4, 2009 | 10:30 PM
Jimmy's Avatar
Global Moderator
Originally Posted by no spark
No spark?
Check your ignition coil..
-Make sure ignition switched is turned to off position
-Remove the dizzy cap
- Disconnect the primary electrical connectors to the coil
- Using an ohmeter touch the probes and compare your results to the values listed.
Testing Ignition coil
Primary resistance 0.6 to 0.8 ohms
Secondary resistance 12.8 to 19.2 k-ohms
Also test your Ignitor (ignition control module)
- Check for battery voltage to the ignition module
- Check the ignition circuit and related componets if there is no voltage to the ICM check the circuit from the ICM to the battery. First check the ignition switch fuses (under the hood fuse box)
- If you get no voltage from the ICM.. Trace the wires down.. See if there is a break in the wire..
- Still no voltage? Your Ignitor is most likely dead.. Replace the ICM.
Old May 5, 2009 | 05:17 AM
JDM_JUNKIE_DA's Avatar
Yo man its gotta be your dizzy..
Old May 5, 2009 | 05:29 AM
1badcrx's Avatar
Originally Posted by Jimmy
done all of that....
Old May 5, 2009 | 06:26 PM
check the connecter on the dizzy im not sure which lines to check because there r many but check that with a light tester and meter be sure to wear protection or u gonna get a hella shocked if u have a chilton manual or sum (15-20 buck) they will show which power wires
Old May 6, 2009 | 06:06 AM
1badcrx's Avatar
i've got ta chilton i'll have to check it out.
Old May 6, 2009 | 06:19 AM
Schister66's Avatar
Man U FTW
CHECK YOUR GROUNDS! I know it sounds dumb but my GSR was parked for a year because of electrical problems (and manifold delays). Just check all your bases because the easy **** is more than likely the culprit. Good luck!
Old May 6, 2009 | 12:25 PM
1badcrx's Avatar
thanks for the help... keep any info coming in
Thecargoddess
Jul 3, 2024 07:09 PM
ecerva5792
Jul 22, 2010 06:20 AM
1badcrx
May 9, 2009 12:58 AM
crxion91
Jan 19, 2008 12:35 PM
CptCorN
Jan 17, 2005 06:33 AM
