Newbie question
Old Jan 13, 2011 | 02:00 PM
LavishTheKid's Avatar
Default Newbie question
sorry guys that i keep posting theses questions, but i need to know what size i will need to get from sears, i stripped my lca bolt that connects to the hub on the rear lower control arm and i can't get a 14mm to fit on their and i tried hammer on a 13mm but im getting tired.
So i want to buy a bolt out kit and i want to know what size's should i be looking to get at sears for a bolt out kit, because they only have a whole set that comes with 10-13 or 14-16mm and i don't wanna waste money.
Old Jan 13, 2011 | 02:40 PM
mouab18c1's Avatar
Default Re: Newbie question
vise grip is probably your best bet.
Old Jan 13, 2011 | 04:28 PM
i can't use vise grips to take off a damn lca bolt
Old Jan 13, 2011 | 04:34 PM
therealnapster8's Avatar
cut the bolt off with a grinder
Old Jan 13, 2011 | 05:02 PM
its not the strut/shock bolt, its the 14mm bolt thats attatched to the brake hub thing so if i cut it i will be ****ed.
Old Jan 13, 2011 | 05:15 PM
Projekt_Ef9's Avatar
The head is a fourteen but i believe the thread thickness is a 12. You want to use one that is closest to the thickness of the thread part but still being smaller. I would get the 10-13 set. Im pretty sure the 14-16 will be too big.
Old Jan 13, 2011 | 05:17 PM
Unless it is the ones that look like sockets and then in that case you need the same size as the head of the bolt.
Old Jan 13, 2011 | 07:16 PM
i was going to get this one.
http://www.sears.com/shc/s/p_10153_1...&blockType=G10
Old Jan 13, 2011 | 07:34 PM
94VTEC2TONE's Avatar
those are baller as ****, get those ive used them many times
Old Jan 14, 2011 | 07:16 AM
^^^^ Yeah get those. My friend has them and they work really well. You will need a set that is the same size as what the head on the bolt used to be.
These work well too but take a lot more time http://www.sears.com/shc/s/p_10153_1...2&blockType=G2
These wrenches are good too but they wont take everything out. If it is hella stripped they will slip too unlike the bolt outs but the wrenches come in handy a lot.http://www.sears.com/shc/s/p_10153_1...4&blockType=G4
Old Jan 14, 2011 | 02:04 PM
hey should i just bought the bolt out kit, should i hammer on the 14 bolt out socket thing onto the bolt or use a 15 bolt out socket?
Old Jan 15, 2011 | 02:41 PM
I have always just used the same size one as the size the head was originally but i have never had to hammer it on there
KKRIS
27
Feb 28, 2012 09:21 AM
Circaskaterr
Nov 23, 2009 09:07 PM
JDM978
Oct 1, 2006 06:30 PM
Setsuna F Seiei
May 12, 2006 09:15 PM
Matt B
Apr 20, 2003 07:12 PM
