New Swap, Starter Problem
Old Jul 5, 2006 | 12:06 PM
Mr Si_Vtec's Avatar
Default New Swap, Starter Problem
OK, i just put in a 98 GSR in my teg and car wont turn over. It just click once and thats it. I changed starter w/ my bro and it still doest turn over. Neep help, thnx
Old Jul 5, 2006 | 03:20 PM
dohcMONSTER's Avatar
Default Re: New Swap, Starter Problem (Mr Si_Vtec)
is the fuel pump priming? can you hear it turn on? we need more info.
Old Jul 5, 2006 | 03:30 PM
Mr Si_Vtec's Avatar
nope, when i try to turn it over all u hear is a click and thats it. battery is ok, but someone told me to check all the ground wires so imma give that a try. thnx
Old Jul 5, 2006 | 03:35 PM
Default Re: (Mr Si_Vtec)
yea definitely sounds like a ground GL
Old Jul 5, 2006 | 04:03 PM
DC2 Mang's Avatar
Default Re: (dohcMONSTER)
any CEL's?
you gotta wait for your cel to shut off before you start the car, the car needs a little time because you can just jump in and start it right up
check your connection on the female/male connector and the bolt on the starter
Old Jul 6, 2006 | 09:56 PM
HATCH DIS CATCH's Avatar
OG BOBBY JOHNSON
Default Re: (DC2 Mang)
Check ground, starter, battery. You might have a low battery, probably its not cranking over.
Old Jul 10, 2006 | 06:41 PM
Mr Si_Vtec's Avatar
Default Re: (HATCH DIS CATCH)
thnx yall, problem fixed, just needed a new starter. but now i got a new problem, i got radiator fluid leaking from under the car. Its leaking from the frame to the shield covering the cat. Need help please.
!97ekhatch!
May 28, 2010 05:59 PM
djviet2000
Jun 9, 2008 06:40 AM
whatcivic
Dec 6, 2005 05:20 PM
Rex_Ryder
Jun 21, 2005 10:30 PM
85DX
Jan 9, 2005 12:46 PM
