New To Me GSR Sedan Project
Old 09-15-2013, 05:42 PM
voz
voz's Avatar
Default New To Me GSR Sedan Project
Was my sons car, he put a hole in the block, he bought a new 2013 CRZ, I inherited a car with a busted motor.
But I will rebuild and replace. She will run again.
The suspension is ****, fart can is too loud, looking for some new stuff...
Was looking at Tokico blue w/ red springs but they in bankruptcy or some type of restructuring ..
Eying Buddy Club Exhaust... Don't want a big *** can,,,
I'm no stranger to turning a wrench.
I want to rebuild my front end, front end is vague and kinda loose.. So I figure I rebuild it..
I have been pricing Moog parts (always had good success with them)
Lower ball joints, tie rod ends...
The rear is another story & I still need a good set of shocks and springs..
It's a daily driver, no racing...
But some spirited driving from time to time..
Old 09-15-2013, 05:45 PM
voz
voz's Avatar
Default Re: New To Me GSR Sedan Project
Old 09-16-2013, 10:24 AM
voz
voz's Avatar
Going by the picture below, I think I need new tires..
Anyways, while new to me tires were being installed I noticed the car is sitting on coilovers.. I could not see any marking on them, don't know the brand... Now I need to raise it a little..
I know how to raise it, but no idea on rebound and such..
But still rather have a spring/strut combo.. I want it lowered, but a decent ride..
Old 09-16-2013, 03:20 PM
Declectic's Avatar
i just got the same color DB8 lol nice!!
I never see a "type r" on a VC before, crazy.
Wow those tires are BALD
GLW build!
Old 09-16-2013, 04:20 PM
voz
voz's Avatar
trying to procure all my parts and install them in one weekend..
Old 09-16-2013, 06:00 PM
voz
voz's Avatar
received my stereo today..
Alpine UTE-42bt - Head Unit - NEW
Alpine KTP-445a - Amp - NEW
10in powered bazooka tube - Was in my Jeep...
Already had Boston Acoustic Speakers all the way around..
Old 09-16-2013, 10:34 PM
TheIVJac|{al's Avatar
Nice, keep the project updated regularly, will be following. Have Fun!
- Aaron
Old 09-17-2013, 10:28 AM
voz
voz's Avatar
Installed all my Stereo crap
PO did not use a harness, he hacked it all up!!!
UPS Man dropped these off to me today!!
SEXii
Old 09-22-2013, 06:37 PM
voz
voz's Avatar
Radio & Alarm installed..
But radio cuts off at higher volumes.. Grounding issue????
Old 09-22-2013, 07:54 PM
90_EX_Civic's Avatar
power issue. you have to run power directly to your battery. it's a known alpine thing.
Old 09-24-2013, 08:07 AM
voz
voz's Avatar
I have not messed with it yet,
Will get it done this weekend..
BTW- That Alpine set up I got sounds pretty freaking good..
Old 09-24-2013, 08:09 AM
voz
voz's Avatar
Just purchased the following off of Amazon...
1ea-Moog ES3331R Steering Center Link Tie Rod End Moog ES3331R Steering Center Link Tie Rod End
1ea- Moog ES3332R Steering Center Link Tie Rod End Moog ES3332R Steering Center Link Tie Rod End
2ea- Moog EV299 Steering Center Link Tie Rod End 2 of Moog EV299 Steering Center Link Tie Rod End
2ea- Moog K9802 Ball Joint
Old 09-24-2013, 08:38 AM
Robs_B18c's Avatar
Just installed my k9802 old ones took some work to get out but new ones slid in perfect.
Old 09-24-2013, 10:14 AM
voz
voz's Avatar
I have access to an OTC Front End Tool Set, does, ball joints, tie rods etc,
Hopefully I can remove them without hurting myself or the car.
Old 09-24-2013, 09:01 PM
j13
j13's Avatar
nice car, more pics! get a block!
Old 09-25-2013, 04:19 AM
voz
voz's Avatar
It has a JDM B18C1 installed...
Timing belt, seals, water pump, plugs, wires & some other items I'm probably forgetting..
She Runs's like a champ.
Old 09-27-2013, 07:52 PM
voz
voz's Avatar
Cluster Issue, I have 3 clusters, that each had a different issue, I combined what I could to make one..
BUTTTTT!!
When I open the door: the ABS light turns on...
When I fasten my seatbelt: the door ajar light goes out...
Temp, rpm, gas & speedo work fine..( which were most important to me)
But I know it will bug me...
Hoping it is an easy fix...
Any thoughts???
Old 09-28-2013, 10:46 AM
deving916's Avatar
What are the clusters?
What years?
The wiring changed when the changed the clusters from 98-01
You may to combine them differently into the right housing
Take a look at this diagram:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/94-97-98-01-integra-cluster-into-92-95-96-00-civic-wiring-diagrams-1053318/
Old 09-29-2013, 07:14 AM
voz
voz's Avatar
AAAHHH!!
I just looked at them and noticed the icon's are in different locations..
I will attempt to swap them from one another..
Hopefully those little red icon thingy s wont give me a hard time..
I'll just get more Jager...
THANK YOU VERY MUCH DEVING916....
Old 09-30-2013, 08:32 AM
voz
voz's Avatar
Box of goodies arrived this morning!!
Old 10-10-2013, 09:57 AM
voz
voz's Avatar
Just ordered the following..
A Set of Tein S Tech Springs & a set of KYB AGX Struts..
Who is going to volunteer to help me install them?
Old 10-10-2013, 10:45 AM
slowDB7's Avatar
they are not that hard to do
Old 10-10-2013, 10:46 AM
slowDB7's Avatar
also what exhaust it that?
Old 10-11-2013, 04:48 PM
voz
voz's Avatar
it's a DC Sport, I want to get rid of it..
Something a little quieter..
Some dude has a used Comptech for 300.00..
Old 10-14-2013, 10:20 AM
voz
voz's Avatar
Suspension Guru's
I have the following
Buddy Club Upper Control Arms
Moog Lower Ball Joints
Moog Outer Tie Rod Ends
Moog Inner Tie Rod Ends
Tein S Tech Springs
KYB AGX Struts
Blackworks Rear LCA's
Ebay Rear Camber Kit
Is anything else needed???
I know my dumb *** is missing something...
Future Purchases
ASR Type rear Brace
Energy Suspension Hyper Flex Master Bushing Kit
Megan Racing Trailing Arm Bushings
Quick Reply: New To Me GSR Sedan Project
