new cluster faces...
Old May 5, 2008 | 10:45 AM
daibloblanco's Avatar
Default new cluster faces...
yea i just bought some new cluster faces for my 94 integra and i was wondering if anyone knew of a how-to guide or maybe some tips to help me?
Old May 5, 2008 | 09:01 PM
BlueIntegraBoy's Avatar
Default Re: new cluster faces... (daibloblanco)
The needles slip through the faces. Use some thin, automotive double-stick tape to keep them in place.
Old May 6, 2008 | 08:06 AM
lmike6453's Avatar
i had to glue them to the original cluster faces because if they stick out a little(center of them where the hole is) and barely touch the needle it will get stuck...
had to tear my cluster apart and fix them a couple times....
Old May 6, 2008 | 08:07 AM
lmike6453's Avatar
and another thing i had to figure out by myself is where to route the positive and negative wires from the inverter box...i ran them to the back of the cluster under screws behind the temperature gauge...
just pm me when you get frustrated
Old May 6, 2008 | 08:35 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 &raquo;</TD></TR><TR><TD CLASS="quote">i had to glue them to the original cluster faces because if they stick out a little(center of them where the hole is) and barely touch the needle it will get stuck...
had to tear my cluster apart and fix them a couple times....</TD></TR></TABLE>
I know I said automotive double stick tape, I meant the photo double stick tape. It's as thin as regular Scotch tape.
Old May 6, 2008 | 10:35 AM
DirtyBirdJR's Avatar
Default Re: new cluster faces... (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
I know I said automotive double stick tape, I meant the photo double stick tape. It's as thin as regular Scotch tape.</TD></TR></TABLE>
that would be great because when you get sick of it or when they finally crap out you wont have super glue residue on the factory faces like I do.
Old May 6, 2008 | 01:06 PM
lmike6453's Avatar
where would you buy this tape and is it cheap?
Old May 6, 2008 | 07:25 PM
Default Re: (lmike6453)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 &raquo;</TD></TR><TR><TD CLASS="quote">where would you buy this tape and is it cheap?</TD></TR></TABLE>
Like at Walmart, Kmart, Target, drug store...
s2kdre
Aug 24, 2007 01:18 PM
Circa
Jun 9, 2006 10:59 AM
BlueIntegraBoy
Jan 20, 2004 10:52 AM
