Neep help Quick!! Please
Old Feb 2, 2006 | 04:45 PM
suken19's Avatar
Default Neep help Quick!! Please
hi guys! I've been posting here about my needles acting weird on both of my rpm and mph gauges and i don't seem to have found the solution to fix it yet. Anyways, does anyone think that if I just swap the whole cluster to another used one (assume that everything works), that it fix my needle problem or there might be other electrical problem causing my needles to be like that?
BTW, is it ok to swap a 94-97 cluster to 98-01 car?
thanks in advance
Old Feb 2, 2006 | 05:05 PM
Sam92Teg's Avatar
Default Re: Neep help Quick!! Please (suken19)
On my 92 RS, the Speedometer started acting alittle crazy. I disconnected the speedometer cable at the tranny, the VSS, and pushed the cable towards the firewall in my hopes to seat the other end at the gauge. Then I reinstalled the cable back at the VSS at the tranny pulling it as least as possible. It fixed the problem and hasn't come back.
Old Feb 3, 2006 | 09:21 AM
suken19's Avatar
Default Re: Neep help Quick!! Please (Sam92Teg)
Is this something that is very easy to do? Can you explain in detail step by step how to do it on a 99 LS if you know how?
thanks
KILLAB17VTEC
Feb 18, 2010 02:33 PM
DC2man
Jun 24, 2008 02:59 PM
rkrone
Mar 9, 2006 03:07 PM
vaporDA6
Mar 10, 2004 10:16 AM
rasta420
Aug 26, 2002 04:25 PM
