Need valves and retainers
Re: (Jimmy)
I want a suggestion.I plan on reving to 10rpm..I knows ima need camshafts.cam gears, pistons, and head gasket. But I wanna get tha valve springs and retainers first..right now stock head under my hood
Re: (B17 Gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B17 Gsr »</TD></TR><TR><TD CLASS="quote">I want a suggestion.I plan on reving to 10rpm..I knows ima need camshafts.cam gears, pistons, and head gasket. But I wanna get tha valve springs and retainers first..right now stock head under my hood</TD></TR></TABLE>
Judging by your intial question, you need to research a whole lot before you even get close to the point of reving to 10k rpm.
First of all, what are your plans and goals for this car? What is your budget?
Re: (B17 Gsr)
your going to need new\modified everything
killerpenguin21
07-21-2006 11:35 AM
IF had to get 1 of 3 which would you get? SS Valves, Springs, or Retainers.. On LS,13-16PSI, and sto
DamonBoost
01-09-2002 06:55 AM
