In need of integra Help!
So this is what I have, 1996 acura integra, obd1 converted LS motor
So I have a check engine code, But theres no way of checking it, when i jumper it out theres nothing there.
When i take it to autozone there machine cant read it im assumming that its all to do with the conversion of obd2 - obd1 but yea.
So anyway it idols high until it warms up thats not an issue, the problem im worried about is the fact that it
1.When i let off the gas 50% of the time the idle goes above 2k rpms
2.it takes off kinda laggy
3.when im holding the throttle at a constant speed and go to give it a bit more thottle or a bit less it kinda lags a bit and feels like a power loss
4.cruise doesent work as well seems like it wants to ingauge but cant hold it
5.i had a lsv obd1 before this and simalar symptoms
o2 sensor?
o2 sensor?
Don't just throw parts at it. The blue jumper pin above the ecu should flash the code. Put a paperclip in it and turn the key on engine off. I have a obd1 computer with conversion harness and it will flash codes.
Yeah I actually tried this once if I recall, but tomarow I can try again.. Thats how I generally do it, I guess now would be a good time to ask if the codes are going to be any different with the conversion? like what codes should i look under da?
vtec-adykt
Apr 14, 2007 10:42 PM
vtec-adykt
Apr 11, 2007 06:24 PM
trust01
Mar 2, 2006 04:18 PM
