need help. turn signal problem.
Old 03-19-2012, 05:26 PM
freshCROOKS's Avatar
Default need help. turn signal problem.
Bought a 99 integra ls a few weeks ago. The passenger side turn signal worked and the driver side didn't cuz there were no bulbs. Got some bulbs for it and now none of the turn signal light turn on except when I'm signal. Any ideas?
Old 03-20-2012, 03:11 AM
Default Re: need help. turn signal problem.
Bump
Old 03-20-2012, 07:49 AM
hbcrazy88's Avatar
maybe you got the wrong bulbs..... you need dual filament bulbs (there will be two wire on the inside) one stays on the whole time and the other flashes for the turn signal.
Bulb sizes:
https://honda-tech.com/forums/acura-integra-6/dc2-integra-bulb-sizes-all-them-need-assistance-2225500/
Old 03-20-2012, 09:50 AM
They bulbs are correct. The tail lights also won't turn on
Old 03-21-2012, 05:00 PM
Let me start over...
My tail lights and front turn signal will not turn on when I turn on my headlights. Turn signal blinks when I use the turn signal. Brake lights turn on when I press the brake pedal. Someone please help me. Is there a rely or switch or fuse I can check??
Old 03-22-2012, 05:00 AM
Can anyone here please help me??
Old 03-22-2012, 06:30 AM
fcm
Old Fart
fcm's Avatar
It is very hard to understand what you mean.
Signal lights do not work but if you turn on the head lights they do work????
With everything off, turn on the hazard lights, do they work, both at the front and rear of car? 94
Old 03-22-2012, 02:03 PM
When I turn on the headlights, only the head lights turn on. The front turn signal is off but blinks the I signal. Tail lights are off but lights up when I step on the brakes.
Old 03-23-2012, 06:27 AM
fcm
Old Fart
fcm's Avatar
OIC, you have no park/running lights, no lights, [of any kind] turn on when you turn the combination light switch one click. is that correct?
Have you checked the "Tail lights, Instrument Panel light, Licence Plate Light fuse"?
Do not just eyeball the fuse, test it or replace with a new or known working fuse. 94
Old 03-24-2012, 12:42 PM
Okay, I guess it was a fuse.-_- I feel dumb. So I have another problem. All the light are on but the right tail light is dim. And when I press the brake, the right tail light shuts off and left one works fine. More help please. I'm not good with electrical issues.
Old 03-24-2012, 02:49 PM
Bump
Old 03-24-2012, 03:33 PM
hbcrazy88's Avatar
you have a bad ground, check you fillaments sometimes those can touch and then ground them out when its not supossed to... if its dim you might just replace them anyways
Old 03-24-2012, 05:09 PM
fcm
Old Fart
fcm's Avatar
As mentioned, it is a grounding problem, the right tail and brake lights share a common ground and it's bad, most common problem is the bulb socket is oxidized, [corroded/dirty]
Remove the bulb and inspect it and the socket, are there signs of corrosion, does moving the bulb around in the socket change anything?
If it is the bulb and socket, replace with a new bulb and spray a little MoveIt or WD40 into the socket to clean it, [plug new bulb in and out a few times to clean the contact points and you should be good to go.
The next most common grounding problem is where the ground lead from the bulb socket is grounded to the cars chassis, in a lot of Honda/Acura that is in the about the center of the rear panel, if the problem is there, remove the grounding screw/bolt clean the ring terminal(s) and the grounding point and reinstall the grounding screw/blot, [if the screw/bolt is rusty, replace it] one of those "star washers" between the ring terminal and the grounding point would not hurt, fixed.
Less common, is a problem with the bulb itself, but it does happen, it is also the easiest to check, swap it with another one, if the problem is now where the bulb you swapped with is, the bulb is the problem, if not, check the ground. 94
Old 03-24-2012, 06:55 PM
The bulbs are good. And yes, the socket has corrosion. I'll check that and the ground first thing tomorrow morning.
TimVanScyoc
03-31-2017 03:22 AM
ohbuckeyes
12-16-2011 10:59 PM
Killtodie
Honda Civic (2001 - 2005)
06-27-2008 03:46 PM
DC4R27
03-23-2007 10:09 PM
Quick Reply: need help. turn signal problem.
