need help with tach!!!
Old May 16, 2003 | 08:30 AM
Train's Avatar
Default need help with tach!!!
i'm installing an aftermarket tach for this guy and i can't figure out where the signal wire goes. everything else is wired up, but when you rev the engine, the tach doesn't repsond like it should.
where does the signal wire go to make the tach read the engine speed?
Old May 16, 2003 | 08:34 AM
P1mpSlap's Avatar
On the harnesss to the right of the master cylinder.
Look for a blue wire. You must splice into that. Also be sure that the Tach (if autometer) is cut for 4 cylinder otherwise it'll read 1/2 of the RPMs.
Old May 16, 2003 | 08:59 AM
Train's Avatar
Default Re: (P1mpSlap)
cool. thanks.
Old May 16, 2003 | 11:07 AM
Train's Avatar
Default Re: (Train)
ok, dumb question: where is the master cylinder located?
Mikey3000
Sep 6, 2006 02:32 PM
A.D.D. Racer
May 24, 2006 09:02 AM
egHondas4Life
Jun 9, 2005 07:34 PM
DevilSolSi
Oct 29, 2002 11:11 PM
